25
In flight, engines provide all the needed energy (bleed air, hydraulic and electrical power). So the APU can be shut down shortly after engines are running. But I imagine that starting the APU in midair is a well known procedure because:
How is the APU used in midair? When is it started/shut down while the aircraft is not on the ground?
If needed, the answers can be restricted to airliners.
44
This answer applies to the AVRO RJ (BAe 146), because this is the aircraft I've flown. Other aircraft may or may not have similar features/issues/restrictions.
Reasons for APU use in mid-air
  • For takeoff, the APU bleed-air can be used to supply the cabin air pressure system to reduce load on engines. This leads to a significant reduction in runway length required. This is routinely used on short runways.
  • Similar reason for the landing, where, for the missed approach/go-around phase, a high climb gradient is required. For example in mountainous areas or combined with icing conditions, where use of engine bleed air is limited, the APU bleed air can feed the cabin pressurization.
  • During flight, when in icing conditions. Similar reason as above. The air-frame anti icing system uses that much bleed-air, there is not much left for cabin pressurization (or the other way round). If the APU bleed-air is used to pressurize the cabin, the (already low) climb gradient is improved.
  • During flight, in the event of a generator failure. The generator of the APU can replace one failed generator of an engine.
  • To save engine life. If APU bleed air (- to pressurize cabin) is used for normal takeoff, the peak engine temperatures will be lower during takeoff. This increases engine life as the peak engine temperature is the main factor of engine life. It's significantly cheaper to replace an APU than an engine.
In all of the above cases, there are restrictions on the operation of the APU. It may not light-up above 15'000 ft or operation above 25'000 ft is not allowed or not recommended. General operating rules for the APU (common sense when using turbines) recommend to use bleed air only after couple of minutes warm-up after startup. Likewise, on shutdown, it should be left running without load to cool down for a few minutes before switching off. The exact timings differ greatly between APU models.
Procedures
  • Before Takeoff, If the APU is not used during climb, the APU is normally shut down during taxi checks. If the pilots decide to use the APU during climb, it is started during normal engine start. In this case the APU bleed air is used to feed the cabin pressurization.
  • After Takeoff depending on the model of the APU (and following airline procedures), the APU usage is limited to a specified time or altitude. Before reaching this limit, the APU has to be shut down. (cabin air changeover to the engine bleed air, cool-off period of the APU, switching off)
  • During Flight In case of a technical problem or emergency, the Abnormal Checklist will suggest or dictate the use of the APU for the remainder of the flight. For example: A generator problem, the APU generator replace the failed generator. This may impose limits to flight altitude and duration.
  • Before Landing Usually after passing 10'000 feet, the APU is started and before the final checks, the cabin pressurization system is switched to the APU.
11
Auxiliary Power Units (APUs) are small gas turbine engines used primarily during aircraft ground operation to provide electric power, air conditioning etc and to start the main engines.
In flight, the APUs can be used for the following:
  • The APUs can be used to provide backup electric power during in-flight operation, in case the main supply fails (or is unable to meet the demand)
  • They can also be used to reduce load on the main engines when power requirements are high (for e.g. in hot and high conditions).
  • In case of an emergency in flight, they can be used to start the engines (Note: The engines can be started in mid air using either cross bleed air or windmilling)
Another thing is that even if the APU fails, most aircraft can operate without any issue using the Ram Air Turbines (RAT).
    $\begingroup$ On the A320, when the RAT is deployed, and the engine generators are inop, only essential electrical buses are operative, see 4th row (emergency generator) in this table from the FCOM. Similarly, only the blue hydraulic circuit is pressurized. $\endgroup$
    – mins
    Jun 19, 2016 at 23:33
    $\begingroup$ RAT (on A320) has just 5kVA. Compared to engine and APU generators that have 90kVA each it is clear it can't power everything (or much at all). $\endgroup$
    Jun 20, 2016 at 14:30
If there is a generator failure in one engine (or an engine problem), the APU can be started to provide electrical power if total demand exceeds the capacity of the remaining engines generators.
