In this answer to a question about reducing engine spool-up time, Peter Kämpf said:
When more thrust/lift is needed, the pilot adjusts pitch and fuel flow to set the desired thrust/lift level. Since the engine is already running at top speed, the change is not delayed by inertial effects.
It seems to me that landing mode or critical mode switch for the engines which would cause the FADEC to spin-up the engine and control power by fuel flow instead would eliminate the lag and increase the likelihood of survival during critical flight regimes.
As an example, encountering a micro-burst during landing will leave the plane wanting power as it flys out of the burst and has a tail-wind, often at low power and low altitude. If, in that situation, the pilot applying additional throttle increased the fuel flow and gave immediate power instead of having to wait for the engines to spool, it seems that would be very advantageous.
Have I understood the concepts correctly, and, if so, what drawbacks to this system might I be missing?
    $\begingroup$ I think Peter was writing about turboprops (and helicopter turbines) - high bypass turbofans don't have variable-pitch fan blades so can't run at full RPM when producing idle thrust. But see Turbomeca Astafan $\endgroup$ Commented Sep 23, 2015 at 19:12
    $\begingroup$ For the turbine to be running at high speed while the fan was idle, I guess you'd need a variable-ratio gearbox or variable-pitch fanblades - see RR UltraFan. $\endgroup$ Commented Sep 23, 2015 at 19:24
    $\begingroup$ @FreeMan The point is that in a turboprop, you can set the pitch so that more torque is needed, and RPM is maintained by injecting more fuel (compare pressing the accelerator going uphill in a car). There is no way to do this on current turbofans, so suddenly injecting extra fuel will just blow up your engine. $\endgroup$
    – Sanchises
    Commented Sep 23, 2015 at 19:53
    $\begingroup$ @sanchises Actually, to be accurate, adding extra fuel in a current turbofan will make it spin faster (which may blow it up, but only if it goes too fast)... $\endgroup$
    – Lnafziger
    Commented Sep 24, 2015 at 9:45
    $\begingroup$ FreeMan, one fallacy in your question is that jet aircraft are at low power settings during landing. In fact, they are designed to be at relatively high power settings during landing, partially so that they are "spooled up" and the response time to add additional power is not as high. $\endgroup$
    – Lnafziger
    Commented Sep 24, 2015 at 9:48
Short answer: no, none of what you describe is possible with current jet engines. You need more fuel because the angle of attack for your prop is increased, not the other way round.
Let's first go into some (simplified) detail how the turboprop works. A turboprop is basically a gas turbine engine with a propeller stuck on the axle. The propeller is the bit that converts the torque and rpm of the engine shaft into a forward thrust. The amount of forwards force is determined by RPM and blade pitch. This means that, even though you're at high RPM, you can 'feather' your propeller so that it doesn't produce any forward thrust (blades flat). At the same RPM, you can just put your blades so that they produce a lot of thrust. Of course, this comes at the cost of increased drag, so the engine has to 'work harder' to maintain RPM. This, in turn, is achieved by injecting more fuel.
Now, to a turbojet. For a turbojet, the thing that produces thrust is exhaust gas going backwards real fast. This is achieved by burning fuel so that the gas gets hot and expands, so that it wants to get out of there as fast as possible. For this, a jet engine needs a lot of air. It sucks in this air by a series of compressors at the front of the engine. Then, some fuel is injected, and after that there are some turbines that make sure the compressors can, and after that there's a nozzle that converts the leftover energy into backwards gas velocity. Now, we want to increase the thrust. This means that gas has to get out of the back faster. Since the nozzle is generally fixed, this means that you just have to get more air out of the back (just like a garden hose with the tap half open or full open). This means that we'll have to suck in some more air from the front, burn some more fuel to make sure the engine keeps spinning, and more air will come out of the back.
Simply increasing the fuel flow doesn't work. Jet engines operate 'lean' (more air than necessary), and the extra fuel you suddenly inject will burn up with all the excess air, which might blow up your engine. If your engine doesn't blow up, you're left with too little air to burn all the fuel, and you'll get a lot of nasty things like soot, carbon monoxide and unburnt fuel coming out of your exhaust. This means you just inject some extra fuel, wait for the engines to 'spool up' so they suck in more air, and like that gradually increase your engine RPM and linked to that the gas velocity.
Two things remain: why use fixed nozzles? This is because physics dictate that, for engines to be efficient, the exhaust velocity needs to be as high as possible; in practice, the exhaust velocity will be as close as possible to the speed of sound in the hot flue gas. Using a variable nozzle would mean that your engine never works efficiently at half power. Furthermore, it adds complexity, weight and thus costs more.
Another thing: I discussed turbojets, not turbofans. In theory, one could have variable blade pitch on a jet engine. However, remember that the fan is not just for thrust (even though high-bypass engines are generally more efficient), but also to make sure enough air enters the compressors; 'feathering' them would mean that your engine might not get enough air. However, your engine would need a lot of air, because it needs to operate very lean to make sure it can handle the extra fuel flow for when you increase the blade pitch. Furthermore, a variable pitch on all blades would mean a lot of complex engineering, which would make the engine a lot heavier.
Long story short: one could design jet engines with variable pitch, but the above wall of text is only the beginning of why that is an engineering nightmare. Without variable blade pitch or nozzles.
  • $\begingroup$ very good answer! Would you think (given a variable nozzle) that an afterburner would do the job? $\endgroup$
    – rul30
    Commented Sep 26, 2015 at 6:48
  • $\begingroup$ @rul30 Yes, it would give an instant power boost (in jet fighters, they're used for TOGA purposes). There are some... how shall we call it, practical problems with fitting flame-spitting engines on a passenger aircraft. Let's say the passengers in the back won't like being deaf and slightly crispy due to a 10 feet long fire straight out of hell. $\endgroup$
    – Sanchises
    Commented Sep 27, 2015 at 10:46
