what are the different ways to avoid skidding off the runway apart from thrust reversers?
Do crew have any option if thrust reversers are not available and the ground is too slippery which is making the vessel skids off the runways sideways?
    $\begingroup$ Why do you assume thrust reversers aid directional control? $\endgroup$
    – casey
    Sep 22, 2015 at 14:42
    $\begingroup$ Thrust reversers are often the reason why an aircraft went off the runway. $\endgroup$
    – user23573
    Sep 22, 2015 at 18:57
Your question appears to assume that thrust reversers are an acceptable way of keeping an aircraft from sliding off a slippery runway. While this may be true in rare cases, generally speaking you would NOT want to use reverse thrust to avoid skidding off a runway as that typically would exacerbate the problem.
Consider the following scenario: you have an icy runway and a strong crosswind from the right. As you start the takeoff roll, the airplane begins drifting left. You apply right rudder to correct, and the aircraft heading moves to the right of the runway direction. If you resolve the engines thrust vector into it's components relative to the runway centerline, you have most of the thrust propelling you down the runway, a much lesser amount propelling you toward the right side of the runway.
Lets say the left drift continues in spite of the engine thrust vector driving the aircraft to the right side of the runway, and you decide to abort the takeoff using reverse thrust. Thus, the thrust vector relative to the runway centerline will slow the aircraft. However the thrust vector 90° to the runway centerline will be toward the left side of the runway, which when added to your leftward drift will likely put you off the left side of the runway.
If you Google "tower air 747 crash" you'll see a number of entries concerning just such a scenario and the result. I found http://flightsafety.org/ap/ap_mar97.pdf to be the most instructive, although I do not wholly agree with the conclusions or with the narrative of what happened (a friend of mine was in the jumpseat right behind the captain, and I flew as a f.o. with that captain).
An obvious answer to your question is to never get yourself into such a serious situation. Can you wait for better conditions? Is another runway available? But if you MUST use a slippery runway for either takeoff or landing (or have already foolishly committed yourself), remember that if a runway is that slippery, it's feasible to continue down the runway in a manner that your course (the runway direction) doesn't match your heading. If the captain of the Tower Air flight had elected to do that, he might not have had the accident he did, or he might have had a much more serious accident. Tough call!
The aerodynamic controls (ailerons, elevators and mainly the rudder for this question) still have an effect when the aircraft is on the ground but is still at speed. So even if the plane slides or aquaplanes a little bit at high speed it is generally controllable.
The problem is at lower speeds when these controls don't work as well / at all. You could be in a situation where the aerodynamic controls don't work and you are going to fast for the wheels to grip, or even you are stopped and a crosswind blows you sideways off the runway.
If the wind is down the runway hopefully you can get down, but taxying might be another matter. Possibly there are reduced cross wind limits on icy runways... I don't know I only fly light aircraft and generally not in those conditions.
Thrust reversers are not used to steer an aircraft.
On the ground the rudder is used to steer during landing and takeoff. The main wheel brakes can be used to make tight turns when taxing.
