16
In my understanding, "F" stands for "fighter" (air-to-air) and "A" for "attack" (air-to-ground). E.g.,
  • the F/A-18 Hornet can attack air and ground targets, which is why it's called F/A-18.
  • the A-10 Warthog is used as an attack aircraft, which is why it's called A-10. However, it's also capable of attacking air targets using IR missiles.
The F-15E Strike Eagle is also capable of attacking air and ground targets. So why is the Strike Eagle still called F-15E and not F/A-15?
    $\begingroup$ Interesting fact an F-15 has never lost a dogfight. $\endgroup$
    – Ethan
    Commented Sep 14, 2015 at 0:56
    $\begingroup$ @Ethan Not True. What happens when an F-15 fights an F-15 at red flag? What you mean to say is than the F-15 has never been destroyed by an enemy aircraft. $\endgroup$
    – Bassinator
    Commented Sep 14, 2015 at 11:48
  • 9
    $\begingroup$ F-15 regularly loses simulated dogfights at red flag against other types. $\endgroup$
    – Bassinator
    Commented Sep 14, 2015 at 11:52
    $\begingroup$ They US Navy didn't re-designate the F-14 either after it was modified to carry and use air to ground munitions. $\endgroup$ Commented Dec 22, 2017 at 12:56
    $\begingroup$ "Not a pound for air-to-ground" $\endgroup$ Commented Apr 12, 2018 at 23:23
21
The aircraft you are mentioning are completely different from each other and some of them are not even named according to the US Tri service Naming System.
In general, the aircraft retain their original designation given even though the later versions have little in common with their predecessors.
The F 15 was a direct result of the studies that followed the Vietnam war and the a response to new generation Soviet aircraft like the Mig-25.
F-15A
"McDonnell Douglas F-15A USAF". Licensed under Public Domain via Wikimedia Commons.
The F-15 was designed purely as a air superiority fighter, with full emphasis on maneuverability and agility with "Not a pound for air-to ground!". The first to variants of the F-15 were called F-15 (single seat) and TF-15 (two seat), which were retrospectively named F-15A nd F-15B after the introduction of F-15C. The F-15E was a strike variant; however, it could defend itself against enemy aircraft and thus retained the 'F' title.
F-15E
"F-15E Strike Eagle" by Gerry Metzler - IMG_214. Licensed under CC BY-SA 2.0 via Commons.
The case of F/A-18 is different. The initial plan was to purchase three different version of the aircraft, F-18A (Fighter), A-18A (Attack) and TF-18A (Trainer). However developments in avionics and some design changes led to the first two versions joined together as F/A-18A and the trainer version being named F/A-18B.
F/A-18B
"US Navy 050803-N-0295M-148 An F-A-18B Hornet, assigned to the U.S. Naval Test Pilot School, folds-up its landing gear after taking off for a training flight from Naval Air Station Patuxent River, Md" by U.S. Navy photo by Photographer’s Mate 2nd Class Daniel J. McLain
Most of the aircraft in service today are multirole and their names mostly reflect what their intended purpose is rather than their actual purpose. With modern avionics and high precision weapon systems, almost any aircraft could be made a strike aircraft
It is to be noted that the naming convention is followed only loosely in some cases. A good example is the F-117 Nighthawk, which is not a fighter aircraft in any sense of the word.
  • $\begingroup$ Good point about the Nighthawk. I've wondered about that before. $\endgroup$
    – codedude
    Commented Dec 15, 2015 at 3:03
  • $\begingroup$ It's important to note that not all two-seaters are trainers. These jets were developed at a time where, as you state, avionics were just improving to the point where one pilot could handle the necessary workload. The "B" (and "D") variants of both planes are fully combat-capable, and could have been the primary service variant if the USAF or USN had considered it necessary to have two people flying the plane (like the F-4 and F-14). That's still true, though less common, in newer designs; the Super Hornet comes in one- ("E") and two-seat ("F") variants, and both are in combat service. $\endgroup$
    – KeithS
    Commented Apr 12, 2017 at 20:17
The F-15A and F-15B came along first, and they were pure air-to-air. (The B model is two-seat so an instructor or observer could ride along.) Then the F-15C and F-15D were built, also as pure air-to-air platforms. (Again, the D model has the back seat while the C is single-seat.)
Then they got the idea for the "E" model, which has the second seat for the WSO and all the various equipment for ground attack. But it's still a model of the F-15. This far into production, it wasn't thought to be necessary to change the designation from F-15 to F/A-15. Maybe if the "E" had been first and the air-to-air variants had come along later, they might have called it "F/A-15," but not necessarily. The F-117 was pure ground attack, and it's an "F" not an "A" like the A-10. The F-16 has lots of ground attack capability, but it's an "F" not an "F/A" designation.
The honest answer is, the Air Force places a low priority on the "purity" of only using the "F" designation on air-to-air platforms and nothing else.
    $\begingroup$ The pilots call the F-15E the Mud Hen (at least some of them do). $\endgroup$ Commented Dec 22, 2017 at 12:59
First off, "F/A" is a non-standard designation under the tri-service designation system. "FA" or "AF" would be standard; the second letter would, according to the system, be the "primary mission" of the aircraft, whichever of those the top brass felt the design was better at. The Hornet would probably have been designated "FA" as its primary goal was to replace the aging A-4 Skyraider as well as to supplement the F-14.
The F/A-18 has that designation because the Hornet was originally supposed to be two planes, the F-18 and the A-18, which would differ only in the required avionics and in minor differences to the weapons hardpoints. "F/A-18" became the internal shorthand for the project as a whole. When it was demonstrated that avionics improvements allowed a single airframe to satisfactorily perform both mission profiles, the "F/A" designator was applied to the production design.
The F-15E should, most accurately, be designated AF-15E, adding a "modified mission" designation for ground attack (similar to other modified mission designations such as the RF-4 reconnaissance variant of the Phantom, or the current EA-18G "Growler" variant of the Super Hornet). Its parent design was a pure air superiority fighter which was modified to produce the Strike Eagle, mainly by strengthening the wings, improving engine output, adding CFTs for better range without droptanks, and replacing practically everything under the skin forward of the intakes (avionics, radar, etc). The Strike Eagle retains much of the air superiority prowess of its lineage, and has been tasked with "Combat Air Patrol" missions often in addition to a primary strike mission (along the lines of "go here, drop your bombs, refuel at this tanker and then stay on station for an hour before heading back"), but its primary mission is ground attack (interdiction, deep strikes, SEAD, etc).
The main reason why the mission designation of the Strike Eagle was not changed is that the USAF has rarely made the distinction between an air-to-air fighter and a light air-to-ground strike aircraft. Pre-1962, any one- or two-man aircraft developed for the Air Force was a "fighter" (evolved from the older "Pursuit" designation in use through WWII) regardless of its specific mission profile. After 1962 with the tri-service system in place, if the aircraft is designed with air-to-air engagements in mind, it is a "fighter" in the USAF's eyes no matter what else it does. The A-10 is the sole production aircraft designed for USAF use to be given that designation (which is fitting as it's designed from the ground up to kill armor, and typically carries only a pair of Sidewinder-Ms for basic self-defense); all other "A"-designated designs in the Air Force arsenal since 1962 have been Navy planes first, with the Air Force having to adopt the pre-existing designation under the tri-service rules. As the Navy's never really been interested in any variant of the F-15 since fairly early in the VFX program, it's only to be expected that the Air Force top brass would ignore the attack designation here.
