I'm aware that I can look at the Wikipedia entry for an aircraft and discover specifications like the MTOW, length, cruise speed, etc. However, I was wondering whether there is a (preferably free) source of all this data combined for most aircraft. Does such a data source exist?
    $\begingroup$ Most? From Wright's flyers up? 2 seaters to A380? Russians built as well as western built and china built? Then there is too many. Can you scope down a bit of what you want? $\endgroup$
    – vasin1987
    Commented Sep 12, 2015 at 2:02
  • $\begingroup$ By MTOW $\endgroup$
    – fooot
    Commented Sep 12, 2015 at 2:57
    $\begingroup$ What you want all planes specs for? Some research or personal use? If you list which plane you want to know maybe someone may have them handy but no one will have specs of most planes at hand. $\endgroup$
    – vasin1987
    Commented Sep 12, 2015 at 12:13
    $\begingroup$ Try this : aircraftbluebook.com/Tools/ABB/ShowSpecifications.do mostly small aircraft though $\endgroup$
    – vasin1987
    Commented Sep 12, 2015 at 12:20
    $\begingroup$ I'm voting to close this question as off-topic because link-only answers are not acceptable on Stack Exchange and they are the only possible answers to this question. $\endgroup$ Commented Mar 29, 2019 at 13:18
4 Answers 4
You can find a lot of information about aircraft in their Type Certificate Data Sheet that is available from the FAA or other certificating authorities. The FAA's is located here. It takes a bit of time to find certain things, and other things aren't included like range, or sometimes dimensions.
  • $\begingroup$ This isn't really what I'm after. These are multiple files, whereas I'd like a single, machine-readable source. If you like, a file where every row is an aircraft and every column is a spec. $\endgroup$
    – Hugh
    Commented Sep 12, 2015 at 3:15
    $\begingroup$ @Hugh It is a single machine-readable source. Your computer is most likely capable of retreiving files from the internet in an automated manner. $\endgroup$
    – usernumber
    Commented Sep 12, 2015 at 9:58
  • $\begingroup$ I disagree. But thank you: this is a comprehensive, if unwieldy, source of data. $\endgroup$
    – Hugh
    Commented Sep 12, 2015 at 10:02
Jane's All The World's Aircraft - Cover Photo
It's not free (Amazon lists it for between \$500 and \$1,000 USD) and it's not machine-readable, but yes, the data is out there.
here is one for a few large transport aircarriers https://booksite.elsevier.com/9780340741528/appendices/data-a/default.htm
Yes there it. The EUROCONTROL Aircraft Performance Database
