My instructor made "request right closed traffic..." call before practicing a series of landings. Just wondering, what is the difference between this request and a "stay in the pattern..." request? Which one should I use when?
Actually, "stay in the pattern" is non-standard phraseology and shouldn't be used, even though it means the same thing as "closed traffic".
Specifying the direction isn't required but it is a good idea to ensure that everybody is thinking the same thing.
$\begingroup$ The answer is clear, thanks, but I learned "stay in the pattern" phrase from Comm1 VFR radio-simulator. This should be popular computer program to train communication skills, does your answer mean I cannot trust/use this software for improve my radio-communication skills? $\endgroup$– barmatatMar 3, 2014 at 7:37
4$\begingroup$ @barmatat "Just because it's popular doesn't mean it's right." (see the ever popular but blatantly incorrect expression "any traffic in the area please advise"). When in doubt refer to the official source $\endgroup$– voretaq7Mar 3, 2014 at 16:39
3$\begingroup$ @barmatat To the contrary, I think that software like that is very useful when you are first learning. However, that doesn't mean that everything is perfect and correct. As with many things in aviation, "trust but verify". :) $\endgroup$ Mar 3, 2014 at 18:14
$\begingroup$ "stay in the pattern" may be non-standard, but "remaining in the pattern" is found in the AIM under UNICOM phraseologies - and therefore is standard, at least for non-towered airports. $\endgroup$– hempFeb 10, 2021 at 4:50
The recommended phraseology depends on the airport. If it's tower controlled then you're encouraged to use ATC's phraseology per JO 7110.65V (3−10−11):
PHRASEOLOGY− LEFT/RIGHT (if required) CLOSED TRAFFIC APPROVED. REPORT (position if required),
For uncontrolled airports we see this in the AIM (4-1-5):
Recommended UNICOM phraseologies:
(b) Outbound PHRASEOLOGY− FREDERICK TRAFFIC CESSNA EIGHT ZERO ONE TANGO FOXTROT DEPARTING RUNWAY ONE NINER. “REMAINING IN THE PATTERN” OR “DEPARTING THE PATTERN TO THE (direction) (as appropriate)” FREDERICK.
Successive operations involving takeoffs and landings or low approaches where the aircraft does not exit the traffic pattern are defined in both JO 7110.65V and the AIM as Closed Traffic. However, the recommended phraseology for UNICOM is to say "remaining in the pattern", whereas for towered operations ATC will always use "Closed Traffic". In practice, pilots and ATC will know what you mean either way.
