Reading the Wikipedia page, I see that the F-16 began production in 1973. That seems pretty old to me. So I ask, why is the F-16 still in service in many countries around the world? Is it that a superior fighter has been not been designed yet, or are there other reasons?
    $\begingroup$ The F-14 is actually the only US fighter from that era that's been totally retired, and even not that long ago. $\endgroup$
    – fooot
    Commented Sep 2, 2015 at 20:20
  • $\begingroup$ @fooot isn't the Iranian air force still flying them? $\endgroup$
    – DeltaLima
    Commented Sep 2, 2015 at 21:26
    $\begingroup$ @DeltaLima I think so. I guess by "totally retired" I should have added "by the US." Much older fighters are also still in use, just not in as many places anymore. $\endgroup$
    – fooot
    Commented Sep 2, 2015 at 22:14
    $\begingroup$ two words: Iron Eagle $\endgroup$
    – elrobis
    Commented Sep 11, 2015 at 15:24
6 Answers 6
24
The simplest answer to your question is that the F-16 has not yet been retired because, for its cost, there's nothing better being built in enough numbers to replace the nearly 4500 Falcons produced.
The F-16 was designed on the trailing edge of a surge in technological development by the U.S. military in the wake of Vietnam. The U.S. had fought that war with an air force primarily designed for a standoff engagement with the Soviet Union directly, thus emphasizing interceptor-style fighters targeting bombers at extreme range using missiles. Robert McNamara, U.S. SecDef for the Johnson and Nixon administrations, also emphasized a "one-size-fits-all" approach to aircraft design, requiring the USAF and Navy to collaborate on common aircraft designs that covered a multitude of mission profiles. This created the F-4, a fast but heavy plane that was a handful to fly, weaknesses that were exploited by pilots of technologically-inferior MiG-19 and MiG-21 aircraft in close combat engagements that the Phantom was ill-prepared to fight.
The lesson "dogfighting isn't dead" prompted a renaissance in jet fighter design in the 70s, producing the F-14 and F-15 long-range air superiority fighters, and the smaller F-16 and F/A-18 multirole fighters. Maneuverability, a wide range of weapons from guns to long-range missiles, and high pilot situational awareness by reducing workload and integrating flight and fire control systems, were all emphasized strongly.
The Soviets were taken somewhat by surprise at this surge; as of when the F-16 first flew, the Soviet air force and those of its allies had nothing that could compete. They answered a few years later with the MiG-29, a smaller twin-engine design similar to the larger Su-27 which was in pre-production to answer the F-15. These six fighters - F-14, F-15, F-16, F/A-18, MiG-29 and Su-27 - represented the cutting edge of fighter design as of the collapse of the Soviet Union in 1991.
The new U.S. designs to enter production since, the F-22 Raptor and F-35 Lightning II, are themselves fairly old; the first production F-22 was built in in 1996 and flew in 1997, almost 20 years ago, the result of a design competition with planes flying back in 1990, and the initial RFP originating in the 1980s. The F-35 first flew in 2006, itself derived from the X-35 JSF testbed which first flew in 2000, so that design is between 10 and 15 years old now depending on how you count. Their protracted development times are a direct result of the reduction in pace of the U.S.-Russian arms race since 1991; with no other technologically-advanced military adversary on the horizon, there simply hasn't been the impetus to get these planes out to the front lines (there is some civilian talk of restarting the F-22 production line to bolster Raptor numbers, as the Sukhoi PAK-FA and Chengdu J-20 are very close to production and the F-35 is way behind projections and proving a disappointment so far, but another 100 new Raptors are projected to cost a ludicrous $225 million each due to increased costs of restarting the line and producing them in parallel with the F-35).
The F-35 also had the handicap of being a return to the "one-size-fits-all" design mentality, being intended as a replacement for practically everything besides the Raptor in the U.S. air arsenal, Air Force, Navy and Marines, with an F or A in its designation. That's caused a lot of technological headaches, since any replacement for the Marines' AV-8B Harrier is going to need STOVL capability, and the Navy and Air Force have always had a different though overlapping set of requirements relating to the Navy's basic need to operate aircraft from a ship at sea that's maybe a fifth as long as the USAF's minimum runway length requirements for its airbases. The resulting design is big, heavy, and relies on the most powerful single engine the U.S. has ever put in a fighter, which pushes the boundaries of the stress limits of the materials we use to make jet engines.
Lastly, military spending in the last 10 years or so has been preoccupied with developing and fielding technology to fight a low-tech insurgency; our enemies know they can't beat us in a toe-to-toe fight, so they don't fight that way, instead targeting our multi-million-dollar military hardware with Vietnam-era milsurp RPGs and oil-drum IEDs costing maybe $100 a shot. On this kind of battlefield, stealth air-superiority aircraft are kind of redundant as the enemy doesn't even have radar, much less an air force to exercise superiority over. That's why the F-22 has never seen real combat; the U.S. has enjoyed "air supremacy" by default in its primary combat theaters, as its enemies have never fielded an air force to speak of.
  • $\begingroup$ "The first production F-22 was delivered to Nellis AFB, Nevada, in January 2003", according to wikipedia. The first "production" aircraft built was in 1996, but the first flight didn't occur until 1997. So, it's not new, but it hasn't actually been in service that long. $\endgroup$
    – egid
    Commented Sep 3, 2015 at 5:52
  • $\begingroup$ Although 4,500+ F-16s have been produced, how many are still in service? The USAF only flies around 1,200 of them; I'm not sure if exports come close to the remaining 3,300 airframes built. $\endgroup$ Commented Sep 3, 2015 at 7:35
  • $\begingroup$ @DavidRicherby - Data from F-16.net suggests the USAF has taken delivery of about half the total F-16 production, about 2500 aircraft. A large contingent of those are mothballed. The Israelis are the next biggest customer with 382 ordered, 362 in service. The Turks have 278, the Egyptians 240, the RNIAF about 230, and there are about three dozen more countries that have taken delivery of enough for between two and ten squadrons. Even the Iranians ostensibly have about 160 of them, though they're probably rusted scrapheaps by now along with their F-14s. $\endgroup$
    – KeithS
    Commented Sep 4, 2015 at 15:26
  • $\begingroup$ @egid The YF-22, which was the demonstrator, flew in 1990. The model from 1997 was also only an engineering aircraft. Over all this time, it cost a lot of money already. It was FOC in 2007, that's 17 years! Contrast that with the F-16, which went from prototype to FOC (1973-1980) in seven years. Also don't forget, that the F-22 isn't produced anymore, while the F-16 is still produced. $\endgroup$
    – mike
    Commented Dec 5, 2017 at 12:53
It fulfills the role it was designed for adequately, a replacement is not needed so why would they stop using it?
The B-52 Stratofortress was introduced in the 1950s and is still in service.
The airframes are older than their flight crews and have undergone extensive refits over the decades, but the basic design is 60 years old.
The F-16, is a fairly cheap fighter to buy and to operate. Despite its age, it is still a very capable fighter if fitted with the right systems. It is not suitable for every theater. It depends on the level of sophistication of the enemies weapons. If they are too modern, it's better to have a different fighter.
Not every country is able to afford more expensive fighters.
I recently read that in a one to one dogfight between an F-16 and the new F-35, the F-16 is still the master.
    $\begingroup$ I agree with that last assessment; the F-35 is hindered by the need to incorporate design features the F-16 was never saddled with. The F-35 has the most powerful single engine we've ever put in a fighter, and it's still considered underpowered for its weight. $\endgroup$
    – KeithS
    Commented Sep 2, 2015 at 22:07
  • $\begingroup$ @KeithS, it seems to have worse thrust/weight ratio than anything else and it also has quite high wing loading, so its turning ability is probably also worse. $\endgroup$
    Commented Sep 3, 2015 at 14:32
  • $\begingroup$ @JanHudec - the F-35 has thrust vectoring, however, which will help significantly on the maneuverability front. $\endgroup$
    – Jon Story
    Commented Sep 3, 2015 at 14:56
    $\begingroup$ The F-16 could easily be upgraded to have thurst-vectoring. It's would not even be an expensive upgrade. One of the pilots that flew it in an operational evaluation told me that in his view, it would never become available to prevent jeopardising the development of next generation fighters $\endgroup$
    – Chris V
    Commented Sep 3, 2015 at 20:16
    $\begingroup$ @JonStory, no. The F-35 doesn't have thrust vectoring. Only the F-35B has thrust vectoring but it's for STOVL operations, nothing more. Besides, thrust vectoring is not sucha good thing on the "energy" front during a dogfight. $\endgroup$ Commented Sep 10, 2015 at 15:52
The F-16 has a thrust-weight ratio of greater than 1, so it is a great dogfighter, it is cheaper than an F-22 or an F-35, and it is being upgraded with faster computers and better engines. Also, the F-16CJ/DJs are the Wild Weasels right now, and when the A-10s are retired, the F-16s will make a decent CAS replacement.
  • $\begingroup$ The X-15 had a thrust to weight ratio greater than 1 as well; nobody'd call that a good dogfighter. The primary determinant of a good dogfighter is high aerodynamic maneuverability, which breaks down into a number of design considerations, of which power-to-weight is only one. $\endgroup$
    – KeithS
    Commented Sep 17, 2015 at 16:08
    $\begingroup$ I also disagree with your assessment of the F-16's capabilities in the CAS mission profile of the A-10. The F-16 was intended for "one pass and haul ass" types of ground runs. It's been used for BAI (destroying enemy forces on their way to the front lines), but it's too fast, too light on internal fuel, too delicate and too expensive to hang around plinking random battlefield targets on demand. The A-10 is one of the cheapest, most durable and well-armed jets of the modern era. $\endgroup$
    – KeithS
    Commented Sep 17, 2015 at 16:21
  • $\begingroup$ Which is why I said decent. And I agree. the TWR is only a small part. My bad. Also, during Desert Storm, F-16s were called in when all the A-10s were out of area. It is true, though, that the F-16 can't function effectively without drop tanks and the help of a tanker. And the A-10 cannot function when there are are AAA sites or SAMS in the area, so the F-16 in it's SEAD role aids it. Good points though, I'l edit my answer. $\endgroup$
    – LBMF_1
    Commented Sep 18, 2015 at 16:43
  • $\begingroup$ F-16's did some fine CAS during OIF. @KeithS think you may misunderstand what weapons and tools are available for CAS. A-10's gun is unique; the GBU-12's it carries are not. Smaller bombes with a variety of guidance packages have been available to the Viper for over a decade. You Don't Have To Have a Warthog if you need CAS. (But yeah, they sure are nice to have ...) Harriers and Hornets also fulfil the CAS role. $\endgroup$ Commented Dec 4, 2017 at 19:38
Well F-16s are old but will fly till 2045 here's how: USAF loves those fighter that are fast,agile,advanced and cheap F-16 has all of them but not advanced so USAF is planning a new production line for F-16 Which is known the F-16V Prototype will be completed in 2016 but F-16 will be even advanced than F-35. Lockheed has given these words In addition F-16V will be supermanueverable like sukoi and F-22 without thrust vectoring nozzles
    $\begingroup$ That's interesting information. If you can link to sources for some of those statements, that would make for a great answer. $\endgroup$
    – FreeMan
    Commented Sep 29, 2015 at 12:17
    $\begingroup$ flightglobal.com/news/articles/… I found this article talking about LM announcing the F-16V at the Singapore Airshow a few years ago, but it looks like it's focused on avionics and radar upgrades. No mention of supermaneuverability or anything like that. There have been plenty of technology demonstrators based off the F-16 that explored supermaneuverability and the like, but I doubt anyone would seriously look into adding that level of complexity to a production version of the F-16. $\endgroup$
    – habu
    Commented Apr 6, 2016 at 18:54
The answer is more of a question. Why retire a fighter jet that can still outmatch fighter jet's today. The F-16 is a reliable tested aircraft. It's had years of edits made to it to make it the best of the best.
