How much drag does a RAT deployment add?
I was watching a simulator video of an A320 dual engine failure at low height during climb out and one step in the protocol was the pilot manually deploying the RAT.
Simulator Video
Since he doesn't manage to make it back to the runway from his 2000 ft engine flameout run I was wondering if not deploying the RAT would make any difference due to reduced drag?
Would the on-board batteries and windmilling engines be able to provide sufficient power for control surfaces?
Also, are there real life incidents of a 2000 ft (or lower) dual engine failure that made a safe return to the runway? Sully Sullenberger's A320 had reached approx. 3,000 ft, yet he was forced to ditch rather than return.
Does the energy management differ drastically from type to type? i.e. Among dual engined aircraft would some be easier to land from a 2000 ft dual engine failure than others? For typical climb profiles, weights etc.
    $\begingroup$ Your second and third questions would probably be better standing on their own as additional questions, instead of tack-ons for this one. It would be easier for future generations to find them that way. $\endgroup$
    – FreeMan
    Sep 2, 2015 at 15:56
  • $\begingroup$ Was that video from a professional simulator or a PC simulator like FS X? Because as far as I can tell (e.g. oaviao.com/oaviao_novo/diretorio_aero/manuais_voo/airbus/…, page 3.3) RAT deploys automatically on A320. And if the video was not realistic in this, I would doubt realism of the FDM as well. $\endgroup$
    Sep 2, 2015 at 17:01
  • $\begingroup$ @JanHudec Looks Professional to me. I've added a link. At approx. 6:10 in the video you can see him do a "Manual ON for the Ram Air Turbine" $\endgroup$ Sep 2, 2015 at 17:18
  • $\begingroup$ Yes, it does look professional. Note however, that the first time around he does not do it. Seems more like “do this just in case it didn't deploy already”. $\endgroup$
    Sep 2, 2015 at 17:42
  • $\begingroup$ @JanHudec From what you mentioned it seems the deployment is mandatory? How much is the drag penalty? Not much I assume? $\endgroup$ Sep 2, 2015 at 17:50
No, because it deploys automatically. Note that in the video in the first attempt the step is not done because there is less time. It is probably included in the checklist just in case the automation didn't do it's job.
Nevertheless, let's try to estimate the drag. All I could quickly find about the RAT is that the attached electric generator provides 5 kW, but that should be enough. We need to take into account the hydraulic pump and power losses, but the generator wouldn't be insignificant part of the load, so we could guess that the turbine does not have more than 50 kW of drag.
Now potential energy is $E_p = mhg$, differentiating by time we get $P = v_{vert}mg$ and solving for vertical speed $v_{vert} = \frac{P}{mg}$. Taking some “median” weight of 60 t (A320 has MZFW 62.5 t and MLW 66 t) and substituting we get:
$$v_{vert} = \frac{50\ \mathrm{kW}}{6\cdot10^4\ \mathrm{kg}\cdot 9.8\ \mathrm{ms}^{-2}} \approx 0.085\ \mathrm{ms}^{-1} \approx 17\ \mathrm{ft/min}$$
So the deployed RAT increases the rate of descent by less than 20 ft/min.
Now the video mentions the best glide speed would be 205 knots (I suppose it is for the 1+F configuration; for clean it sounds too low, though I don't have a reference for this). Since the L/D ratio is around 18, that would give the total descent rate about:
$$v_{vert} = \frac{205 \mathrm{knot}}{18} \approx 11 \mathrm{knot} \approx 1150 \mathrm{ft/min}$$
Except, well, 18 is clean L/D. The L/D at 1+F is a bit lower. I don't have reference for that either, but something like 10–12 sounds right, so:
$$v_{vert} = \frac{205 \mathrm{knot}}{12} \approx 17 \mathrm{knot} \approx 1730 \mathrm{ft/min}$$.
That is about 100 times more. So the RAT might increase drag by 1%. It was very rough estimate, so it may be 2% or 0.5%, but it definitely isn't that significant.
The training manual mentions that
If engine wind milling is sufficient, additional hydraulic power may be recovered.
without saying at what speeds that would be, but generally the speed for wind milling engine restart are significantly higher that the best glide speed. I'd say the necessary speed would be more than 250 knots.
I can't find any other incidents involving dual engine failure on A320-family aircraft besides US Airways 1549. And I am not aware of any incidents on any other aircraft that would fit that criteria either.
It should however be noted, that flight 1549 likely had enough altitude to return to the runway—if the manoeuvre was executed perfectly. A small mistake and they'd crash into populated area since the airport is in the middle of a city. The Sullenberger's great airmanship was in that he chose the worse option that he was certain he can make over the better option where he was not.
Principally it's the same for any type. But since turn radius increases drastically with speed, slower aircraft can turn faster and thus could return from lower altitude.
Here's a related question that discusses the manoeuvre; and it's dangers: Is it even remotely feasible to turnback a single engine aircraft with an engine failure?
  • $\begingroup$ Fantastic answer! Thanks! $\endgroup$ Sep 2, 2015 at 18:31
  • $\begingroup$ @curious_cat, I added a link to related question which discusses the turning back in some more detail. $\endgroup$
    Sep 2, 2015 at 19:02
  • $\begingroup$ @JanHudec good call on the 10x multiplier for useful power extraction from flow - this is supported by Hoerner's Fluid Dynamic Drag and Fluid Dynamic Lift books (and another paper I can't find now) $\endgroup$
    – costrom
    Jan 17, 2017 at 19:52
