Reading about the Airbus E-Fan and it's dual 30 kW thrust fans caused me to wonder: assuming the need for four electric fans, how many kilowatts would be required to power each fan with enough thrust to get a Boeing 747-8 airborne?
1$\begingroup$ How do I turn this into a community question? I feel completely unqualified to mark any answer as the accepted one since I don't have the electrical and physics background to know if any answer is accurate or best. I asked the answer hoping to be enlightened but don't consider myself a suitable judge to rate the answers. $\endgroup$ – Mike C. Sep 1 '15 at 19:08
12$\begingroup$ The point of allowing users to vote on answers is to show a consensus on what the best answer is. If you don't feel qualified to accept an answer, then you don't have to do so. Changing it to a community question won't change any of that, and will also prevent users that answer from earning any reputation. $\endgroup$ – fooot♦ Sep 1 '15 at 19:53
$\begingroup$ Another way to calculate it is to do it from fuel: say we use 747's data: 8mg/n*s of SFC, with take off thrust being 1100kn, with JP-A being 40MJ/kg, and thermal efficiency being aroung 40%, we arrive around 140MW. If you drive the fan with electric motor, it's subject to the inefficiency of the fan, too. 90MW calculated as below is the output power of the fan, but in practice the shaft power that drives the fan needs to be higher. $\endgroup$ – user3528438 Sep 29 '17 at 21:41
$\begingroup$ Instead of the you can use a small nuclear reactor for powering the turbofan. That reactor is save as it is pressurized water $\endgroup$ – kumar swamy Jan 9 '18 at 10:17
First, let's figure out how much power a 747 needs to takeoff:
Assume:
- Engine thrust = 284 kN
- Takeoff speed = 170 knots
- Takeoff power = 90% max power
Using $P=Fv$, converting the variables to SI units, we get $$Power=88,948,800 W$$
Or, in other words, around $90MW$.
EDIT: This calculation is only correct if the engine efficiency is 100%, because it is based on work done. For a realistic estimation, see Jan Hudec's answer. I'll leave the rest of this answer based on 90MW as I'm too lazy to update the numbers.
But just exactly how much is 90 megawatts?
An average laptop computer consumes 20W on daily use. You can power 4.44 million laptops with this power.
A high-end desktop consumes 300W under heavy load. You can power 300,000 desktop computers. If you stack 20 of them in a server tower and put 100 towers on each floor, you need a data center with 150 floors to fit those machines in.
Let us take this a step further and evaluate the total energy needed for a flight. Assume all required energy comes from onboard energy storage (i.e. no solar panels / windmills). Let's also assume a full power climb to cruise altitude of 15 minutes, 50% power cruise for 4 hours, and a completely idle descent which does not consume any power at all.
Using $E=\int P dt$, we get the total energy needed for a flight is $$720,485,280,000 J$$
With that amount of energy, you can pull a 735 kiloton object up 100m. If all those weights are water, that's close to 300 Olympic swimming pools.
If you power the whole plane with batteries, you'd need 47 million AA batteries.
Of course, if you manage to get 14 of these electrical 747s together, you can generate 1.21 gigawatts and get Back to the Future.
5$\begingroup$ Without the use of superconductivity there is no electric motor technology currently available that would be light enough to be a viable candidate to turn the fan to achieve such power. Jet engines just have extreme power densities $\endgroup$ – Chris V Sep 2 '15 at 21:28
3$\begingroup$ Thanks for putting that 90 MW into perspetive. All this can be seen as an argument againt electric flight but I just see it as an ode to how much energy is stored in a fossil fuel. $\endgroup$ – Jonny Sep 3 '15 at 5:50
1$\begingroup$ @kevin is that so? Have a look at en.wikipedia.org/wiki/Arcjet_rocket . But feel free to replace 'jet' in my comment with 'turbine'. $\endgroup$ – bogl Nov 11 '16 at 12:31
1$\begingroup$ @kevin ... as well as en.wikipedia.org/wiki/Jet_propulsion. Any machine that jettes out a stream of matter for the sake of propulsion could be named 'jet engine'. $\endgroup$ – bogl Nov 11 '16 at 12:39
6$\begingroup$ 90 MW? You are from an efficient county! 90 MW won't get a 747-8 anywhere! The problem is that you only count the work done on the plane. That is enough when talking about wheel-driven vehicles, which use huge reaction mass (Earth) that can absorb any amount of momentum with practically zero work. But aircraft don't have that luxury. Their only available reaction mass is the air and that takes a lot of energy with the momentum. $\endgroup$ – Jan Hudec Dec 6 '16 at 20:55
I can't quickly find the necessary numbers for 747-8, so I'm going to go with the numbers for Rolls-Royce RB.211-524G-T, one of options on 747-400, taken from here.
The engine can produce static thrust
$$ T_s = 58,000\ \mathrm{lb}_\mathrm{f} = 258\ \mathrm{kN} $$
using mass flow rate of
$$ \dot m = 1,604\ \mathrm{lb/s} = 727.5\ \mathrm{kg/s} $$
Now due to principle of action and reaction, the engine must apply the thrust to the air passing through it. We know that $ F = ma = m\frac{\Delta v}{t} $ and using $ m = \dot m t $ we get $ F = T_s = \dot m \Delta v = \dot m v_e $, where $\Delta v$ is change of velocity of the air inside the engine, which is equal to exhaust velocity $ v_e $, since we are starting with still air. We can solve for exhaust velocity:
$$ v_e = \frac{T_s}{\dot m} \approx 355\ \mathrm{m/s} $$
That's pretty fast. In fact, it is mildly supersonic, though in practice it is average of the just subsonic bypass flow and the faster hot core flow (in which the speed of sound is higher).
We also know that kinetic energy is $ E = \frac12 m v_e^2 $ and, deriving by time, power is $ P = \dot E = \frac12 \dot m v_e^2 $.
So we can substitute:
$$ P = \frac12 \dot m \frac{T_s^2}{\dot m^2} = \frac{T_s^2}{2\dot m} = 45.7\ \mathrm{MW} $$
That's one engine.
Total power is 183 MW.
For 747-400 with this particular type of engines. Different engine options will have slightly different powers, because they use somewhat different mass flow rates for the same thrust. And of course, 747-8 will have a bit more.
The above also used static case. At higher speeds, the pressure recovery allows turbine engines to produce even more power, but by the end of take-off run, the pressure recovery is not significant yet and at altitude, the lower overall pressure limits the output, so this does correspond to the maximum power the engine develops.
With some losses, we are looking at at least 200 MW power input. All the numbers in kevin's answer need to be multiplied by 2-and-a-bit.
$\begingroup$ I note the Industrial RB211 is rated at 32 MW. I infer that this would be down-rated from the aero-engine version to support prolonged continuous operation - so I take this as support for your answer. $\endgroup$ – Crosbie Dec 7 '16 at 22:07
2$\begingroup$ @Crosbie, indeed, the 32 MW is most likely the maximum continuous power, while I am estimating the take-off thrust, which is limited to 5 minutes, here. Plus the part of power provided by the hot stream is included here, but not for the industrial version. $\endgroup$ – Jan Hudec Dec 7 '16 at 22:10
$\begingroup$ The end velocity of 355 m/s would be obtained if the exhaust converts all gas energy into kinetic energy. A convergent exhaust cannot produce supersonic gas streams, and part of the thrust will be delivered as increased static pressure times exhaust area. $\endgroup$ – Koyovis Sep 30 '17 at 2:29
1$\begingroup$ @Koyovis: The core exhaust is even faster but still subsonic. Please consider what the speed of sound is in air of 600°C! $\endgroup$ – Peter Kämpf Nov 23 '17 at 23:58
Well, the GEnx-2B67 engines with which the 747-8 is fitted each produce a maximum of $ 284 \mathrm{kN}$ thrust (according to its Wikipedia page). This translates to a total of $1136\mathrm{kN}$, since it has 4 engines.
Power, which has the units Watt, is the product of force (thrust) and velocity.
The 747 has a takeoff speed of about $290 \mathrm{km/h}$, according to this page.
Assuming the 747 requires all its available thrust for takeoff, the power it requires can be found by multiplying its velocity by the force pushing it forward (in the case of an airplane, its thrust).
First convert these to SI units: $$1136 kN = 1136000 N$$ $$290 km/h = 80.55 m/s$$
We now multiply these to get the power:
$$ P = 1136000 \cdot 80.55 = 91504800 W = 91.5 MW $$
So, for takeoff, the 747-8 will require approximately $91.5 \mathrm{MW}$ of power.
This is a very crude estimate. Firstly, the maximum thrust listed on the engine's Wikipedia page is likely its maximum static thrust, when it is standing still. When it is moving forward at $290 \mathrm{km/h}$ at takeoff, this thrust will be slightly less.
Also, if you want to provide this power with electric motors and fans, there are inefficiencies associated with both the electric motors and the fans, which will mean that the actual motors used will in total need to be able to produce quite a bit more than $91.5 \mathrm{MW}$.
The weight of such motors will be monumental. And these motors will need to be fed by an energy source, batteries or hydrogen fuel cells come to mind, and the weight of these will be just as large.
Electric motors are quite efficient in converting energy, but the energy storage devices that will feed them have very low energy densities (read energy per weight).
Internal combustion engines are quite inefficient in converting energy, but the fossil fuels that they use have an extremely high energy density.
3$\begingroup$ Note that the engines are not always run at maximum rated thrust for a takeoff, so the real-world numbers may be (slightly) more favorable - still the answer is "Probably a lot more Watts than we have space for batteries onboard." $\endgroup$ – voretaq7 Sep 1 '15 at 18:57
1$\begingroup$ So, um, a lot! Current battery tech is somewhat suitable for moving a car down the road, but not for getting a commercially viable aircraft off the ground. $\endgroup$ – FreeMan Sep 1 '15 at 19:09
3$\begingroup$ There is also the weight of copper needed to shift all those amps around. $\endgroup$ – Simon Sep 1 '15 at 19:27
5$\begingroup$ This is the sort of situation that makes one think how under-appreciated the extremely high energy densities of hydrocarbon fuels are. Perhaps because they are so ubiquitous people don't appreciate them as much. $\endgroup$ – curious_cat Sep 1 '15 at 19:42
3$\begingroup$ You are from an efficient county! The value you calculate is the work the engine does on the aircraft. But since aircraft don't have the luxury of huge reaction mass (Earth) that can absorb all the needed momentum with negligible work, there is also the work the engines do on the air. And if you calculate the energy that way (which requires finding a mass flow rate through the engine), you'll get twice as much! $\endgroup$ – Jan Hudec Dec 6 '16 at 21:50
A single 777 engine develops 108 megawatts of power, with 2 engines, that is 216 megawatts...you are going to need more than 90 megawatts taking off in a 747 if you want to live.
I know this isn't the exact answer to your question, but perhaps this will give you some perspective that other answers haven't.
The Airbust E-Fan electric motors produces 30 kilo-Watts of power. That is equivalent to about 40 horsepower. There are two of these, for a total of about 80 horsepower.
The first airplane I soloed in was a Cessna 150. It was fitted with a 200 cubic inch four cylinder internal combustion engine and could barely carry two people.
Additionally, the Wright Flyer was powered by a four cylinder internal combustion engine that produced 12 horsepower.
As others have shown, the total takeoff power of the 747 is about 90 Megawatts, which is about 120,000 Horsepower. In other words, you would need about 1,200 of the Cesnna 150 engines, or 3,000 of the Airbus E-Fan motors, or 10,000 of the Wright flyer engines to produce the same amount of power.
It's completely unfeasable. Without all the calculations (accurate as they may be) a very large Boeing (737 or 747) can't be make airborne with electricity/batteries alone. Maybe hydroelectricity could.
A Tesla mark 3 has about 6200 'laptop batteries'. They weigh about a 1000 kilo's. The electricity regenerated per battery is not that big: about a laptops requirement. The weight would be significant versus the weight of the plane, or the weight of the plane plus the weight of the kerosine.
For making it available for a very large jet (!) fueled engine, enormous techical achievements have to be made.
Can an elictrical powered engine be converted in a jet fueled one? Not with current technology, I think.
John
2$\begingroup$ Can you provide some sources for your claims please? $\endgroup$ – dalearn Dec 22 '18 at 21:46
