High altitude atmosphere has lower oxygen level. How do aircraft, especially the military ones, prevent engine flameout?
The oxygen level at high altitude is the same as at sea level, namely 20.95%. What is lower is the oxygen pressure.
To avoid flameout, pilots must avoid to throttle the engine down too much, so a minimum pressure in the combustors can be maintained.
Designers can increase the altitude performance by building longer combustors. The speed of ignition is pressure dependent, and with lower pressure it takes longer for the fuel-air-mixture to ignite. More length allows more mixing and leaves the mixture more time to react. Also, they can add flame holders which leave pockets of burning fuel close to the injection nozzles, so the mixture is heated more rapidly and ignites more reliably. Normally, flame holders create drag and are reduced to the minimum necessary.
1$\begingroup$ Throttle up or down? I assume down but I have no time in jets. $\endgroup$ – egid Aug 30 '15 at 22:19
2$\begingroup$ @egid: I think "throttle" is usually used as a synonym for the verb "limit"? I don't think I've ever seen it as a synonym for "relax"/"increase"/etc. $\endgroup$ – user541686 Aug 30 '15 at 23:34
1$\begingroup$ @Mehrdad that's true, but in aviation, the throttle is the control for how much power the engine delivers. I've heard it verbed as "throttle back", down, up, etc.; it seems to be more useful with a modifier. Limit in this example doesn't make sense either, fwiw: "pilots must avoid to limit the engine too much". $\endgroup$ – egid Aug 31 '15 at 1:14
1$\begingroup$ @egid: Mehrdad's understanding is correct (the context was probably helpful), but I agree that clarity of this sentence can be improved. Edited. $\endgroup$ – Peter Kämpf Aug 31 '15 at 6:25
1$\begingroup$ @egid, most descriptions I've read insisted that turbines don't have anything called ‘throttle’. They have ‘power’ levers in turboprops and ‘thrust’ levers in jets. $\endgroup$ – Jan Hudec Aug 31 '15 at 6:38
At high altitude, aircraft engines have a number of built in safeguards to prevent flameout, like,
The engine igniter is on continuously. This continuous ignition is set automatically by the FADEC if flameout conditions are detected.
In case flameout occurs, the FADEC tries to restart the engine automatically (in response to loss of thrust, for example).
The engines also have compressor bleed valves, which serve to prevent compressor stall in case a sudden increase in thrust is demanded from the engine.
Also, as Peter says, at high altitude, the percentage of oxygen remains the same, but the partial pressure is less.
$\begingroup$ Better answer IMHO as it actually answers the question as it was asked. +1ed $\endgroup$ – Alexus Aug 31 '15 at 22:21
No, it doesn't. $\endgroup$ – Simon Aug 30 '15 at 17:51
