I have tried to ask this in chat and I have been invited to ask a full fledged question here.
Is it true that an old (say about between the two world wars) take-off technique, to compensate for the p-factor experienced at high throttle settings, was to put the aircraft misaligned to the runway and let the p-factor align the aircraft to the center-line?
Example: take an aircraft with a p-factor that makes it yaw to the left, the pilot would have placed the aircraft on the left side of the center-line, with the nose to the right (so, looking at the center-line).
    $\begingroup$ Never heard of that method, but in his Taildragger Tactics book, Sparky Imerson describes how to land on a slight diagonal down the runway to help reduce crosswind component, so there's no telling how creative pilots can get when they have to. $\endgroup$ – habu Aug 25 '15 at 7:13
  • $\begingroup$ An off-center takeoff gives the pilot a better view of the runway. Airplanes back then were almost all taildraggers, and forward visibility on the ground was poor. $\endgroup$ – Peter Kämpf Mar 24 '17 at 20:04
Why ask in past tense? The Mü-23 motor glider has a central wheel and would need someone to hold a wingtip during take-off. Sometimes, a different technique is used: The aircraft is parked at a right angle to the (grass) runway, with the wingtip pointing into the intended take-off direction on the ground. When the pilot opens the throttle, he steps on the rudder, causing the aircraft to swerve into the desired direction and rotating into a horizontal attitude thanks to the centrifugal force.
Akaflieg München Mü-23
Akaflieg München Mü-23 (picture source)
|improve this answer|||||
    $\begingroup$ Why I ask in past tense? From the wiki page: Number built 1 not exactly common to come across, is it? :P $\endgroup$ – Federico Aug 25 '15 at 7:23
  • $\begingroup$ @Federico: Unless you are flying from the Königsdorf airfield. $\endgroup$ – Peter Kämpf Aug 25 '15 at 8:11
    $\begingroup$ Also, this aircraft seems to be doing it because of the single wheel, not to compensate for the p-factor. Are there examples of aircrafts/pilots doing it for p-factor related necessity? $\endgroup$ – Federico Aug 25 '15 at 8:21
    $\begingroup$ @Federico: I admit, this is not answering your question. But p-factor is also at work when uprighting the Mü-23. $\endgroup$ – Peter Kämpf Aug 25 '15 at 10:22
    $\begingroup$ Peter, as you mention, this does not answer the question, but it is upvoted, meaning that the system behind SE thinks that my question is answered. Could you help me having a chance of receiving an answer? $\endgroup$ – Federico Nov 8 '17 at 12:01
