18
I've never understood the purpose of yawing, i.e., rotating around the vertical axis by activating the rudder. Provided that airplanes have ailerons that allow banking (used for turning), why do they actually need to yaw? Furthermore, I've read that yawing induces an undesired banking because of the different lifts generated by each wing, due to the fact that one wing "feels" a higher airspeed than the other (a similar effect as a car's wheel spinning faster than the other during a turn). So, if yawing is so "useless" or bothering, why do airplanes have rudders? Moreover, could an airplane takeoff, fly and land without rudder?
  • 9
    $\begingroup$ @Claudix the ailerons induce yaw in the opposite direction of your intended turn. $\endgroup$
    – casey
    Aug 17, 2015 at 18:18
  • 7
    $\begingroup$ No. Yaw can be caused by the engine, by wind, by the ailerons, ground conditions when taking off and landing, by "weather cocking", etc. You use the rudder to induce opposite yaw to prevent turning around the Z axis. $\endgroup$
    – Simon
    Aug 17, 2015 at 18:47
  • 27
    $\begingroup$ I read it as "yawning" and was confused why this was asked on Aviation.SE. $\endgroup$
    – user541686
    Aug 17, 2015 at 19:15
  • 9
    $\begingroup$ @Claudix: Yeah, I was just praying it wasn't a pilot issue. $\endgroup$
    – user541686
    Aug 17, 2015 at 19:48
    $\begingroup$ (continued) The reason rudder yaw induces a bank is because the tail is not aligned with the center of mass. The CoM is in the middle of the fuselage, and the tail (and center of the rudder) sticks up rather high above it. Therefore, you get this slightly diagonal torque-arm acting on the body of the plane instead of a nice straight, perpendicular line. $\endgroup$
    – DrZ214
    Aug 19, 2015 at 3:09
7 Answers 7
39
From a totally practical standpoint, let's say you're in a small tricycle gear aircraft with a freely castoring nose wheel (or a tail dragger) and you're starting your takeoff roll in a calm wind. When you bring the power up, the aircraft is going to want to turn left (why is another question), in other words to yaw about its vertical axis in a counter-clockwise direction, and head for the grass off the left side of the runway. You counteract that adverse yaw by using right rudder to keep the airplane straight. Initially you might have to use some right brake as well until there's sufficient air moving past the rudder. If you had a steerable nose gear, you wouldn't need the right brake.
You reach flying speed, apply up elevator, and lift off. As the airplane rotates about its lateral axis, there'll be some additional adverse yaw as a result of that rotation (again another question). Even if you had a steerable nose gear, that would now be useless as the nose gear is no longer on the ground. Your means of continuing to fly straight ahead is to counter the adverse yaw with rudder, and you would continue to use right rudder as you climb out. If you don't, you'll start turning left.
You reach the altitude you want, level off, and trim for level flight straight ahead. Then you decide you want to turn left. You start the turn briskly with left aileron, but you forgot to use any rudder. If you were looking at the ball on the bottom of the turn and bank indicator, you would see it shoot left. If you had used left rudder while initiating the turn, that wouldn't have happened. You would have started a coordinated turn.
Now you're coming back to the airport, and there's a crosswind from the left. You decide you want to counter that crosswind by slipping into it. In other words, you want the airplane to travel sideways at a speed that matches the crosswind while still having your nose pointing straight down the runway. So, you lower the left wing and to keep the airplane from turning, you use right rudder to keep the airplane aligned with the runway. You match the crosswind by adding or decreasing your bank.
There are other uses of rudder, and especially in aerobatics.
I once flew a few loads of skydivers. The jumpmaster sat behind me, and to help him in positioning for the drop zone, he wanted flat turns. In other words, he wanted the airplane turned while keeping the wings level. So, if he wanted a left turn, that meant left rudder and right aileron. Uncomfortable from a pilot's standpoint.
Finally, back in the 1960s when I was working on my instrument rating, I had an instructor who taught that the best way to track a localizer in close was to use rudder only for small corrections. Personally, I don't like that method, but it's one way of doing things.
A useful thing, the rudder. You need to be able to directly control movement about all three aircraft axes.
  • $\begingroup$ Great answer, sir. Missed the answers (short, at least) to those "another questions", though :-) $\endgroup$
    – Claudi
    Aug 17, 2015 at 19:44
  • 7
    $\begingroup$ @Claudix You're free to ask those other questions as other questions. It just fits this site's format better, though, if they're asked as separate questions rather than all answered in the same place. It's easier to find what you're looking for from a search engine and the answers are more concise and readable that way (among other reasons.) $\endgroup$
    – reirab
  • $\begingroup$ I know :-) However I'll try to find the answer on the Internet first! And by the way, thank you for your detailed answer! $\endgroup$
    – Claudi
    Aug 17, 2015 at 19:50
  • $\begingroup$ Is "why" because of the right-hand rule? $\endgroup$
    – jfa
    Aug 17, 2015 at 22:11
  • $\begingroup$ @JFA, the direction depends on the direction of rotation of your propeller. Most propellers turn clockwise, leading to left yaw $\endgroup$
    Aug 18, 2015 at 6:14
16
The purpose of yawing is, as you note, to provide a way to rotate the airplane around a vertical axis. Ailerons can roll the airplane around a longitudinal axis and produce a slipping turn, and turning with the rudder alone produces a skidding turn, but proper turning is a combination of both aileron and rudder inputs and produces a coordinated turn.
Turning with aileron alone creates adverse yaw when the rising wing provides more lift and more drag than the lowering wing, causing a yawing moment away from the intended direction of turning. Additionally, if you want to maintain effective gravity downward in your reference frame, you need a yaw moment and rudder is what provides that.
There are many other situations where rudder is essential to flight
If rudder were useless, we wouldn't have them. There are airplanes without rudder pedals, e.g. the ercoupe but this plane still has rudders that act in accordance with the ailerons through turning the yoke to provide the necessary forces for coordinated turns.
    $\begingroup$ Stopping the people in the back puking is also a good use of rudder. $\endgroup$
    – Simon
    Aug 17, 2015 at 17:53
  • $\begingroup$ @casey, I think you meant, in the second paragraph, "Turning with rudder alone creates adverse..." $\endgroup$
    – Claudi
    $\begingroup$ @Claudix no, I meant what I wrote. See the link and go ask a CFI to demonstrate this to you in an airplane if you are skeptical. $\endgroup$
    – casey
    Aug 17, 2015 at 18:20
  • $\begingroup$ Sorry, I didn't mean to seem skeptical. I didn't know ailerons induced yawing. $\endgroup$
    – Claudi
    Aug 17, 2015 at 18:25
    $\begingroup$ There are also situations where yaw alone is directly useful to introduce intentionally uncoordinated flight, for example, a slip to landing. Fly a tailwheel airplane, maybe even an old one with no flaps, into a short field and this is de rigeur for achieving a steeper descent profile without gaining energy and airspeed. It's also how to correct for a crosswind on approach and landing. As a CFI, that's the first answer I'd think of when reading the OP's question. $\endgroup$
    – RobP
    Aug 17, 2015 at 20:41
The primary purpose of yawing is to stop yawing.
Airplanes with long wings have a tendency called adverse yaw. Adverse yaw causes the plane to yaw away from the direction of turn when attempting to turn using ailerons and elevator. The more you try to turn left, the more the nose point right.
The big problem with adverse yaw (apart from it being potentially confusing to pilots) is that while the lift from the wings held at a bank angle is trying to turn the plane in one direction, the nose is going in the wrong direction eventually causing the plane to stall. This can make turning impossible.
Early aerodynamicists didn't fully appreciate adverse yaw because experiments with model planes tended to have the plane fly straight. It's not until you attempt a turn that you'd encounter adverse yaw. Even early glider pioneers didn't fully appreciate it much because a lot of the early hill hopping glider flights were also in straight lines.
Among the first people to encounter and attempt to solve the problem of adverse yaw was the Wright brothers. Taking inspiration from other early glider pioneers and large kite fliers their early gliders didn't have a rudder. They found that it was unstable when the wings tip to either side (bank). What they experienced was adverse yaw. Their solution was to add a vertical stabilizer and it solved the problem for the most part. Later they made the rudder movable to allow the pilot to further correct for adverse yaw manually. We still teach this "correction" maneuver - it's called the coordinated turn.
  • $\begingroup$ I'd like to note that these days there are other ways to overcome adverse yaw including (but not limit to) aileron differential, drag rudders, spoilerons (technically a variant of drag rudders when used this way) and low aspect ratio wings. It's just that the rudder was invented as a solution to adverse yaw. $\endgroup$
    – slebetman
    Aug 18, 2015 at 7:31
A turn performed with just the ailerons and elevator will not be "coordinated". This is to say, the apparent G force will not go straight "down" through the aircraft's floor, which is desirable for various reasons. Among them is passenger comfort (being pulled down is less unpleasant than being pulled sideways), but there are other advantages too.
In addition to making coordinated turns, the rudder is useful to correct yaw induced by gusts of wind, to set up and maintain a wing down attitude in a sideslip crosswind landing, to quickly lose altitude without picking up lots of speed (somewhat notably used by the Gimli Glider), and for various aerobatic maneuvers.
To my knowledge, at least during combat/ww2 Using the rudder to yaw in that way was often applied by pilots who were weary of being attacked from behind. Adding a small amount of rudder/aileron to yaw, meant that instead of flying straight and level, the aircraft would sideslip through the air, therefore throwing off any enemy fighters aim/Bullets. Any combat airman will tell you, never ever fly straight and level in a combat zone...
    $\begingroup$ Welcome to aviation.SE! This is an interesting answer but yawing also increases drag and reduces speed, which would presumably be a disadvantage in a dogfight. Do you have any sources you can link to that mention this technique? And if you're new to the site, the tour may be useful. $\endgroup$
    – Pondlife
    Nov 24, 2018 at 0:04
Absolutely. I have an electric ducted-fan model of an F-16 that has ailerons, elevators, and a steerable nosewheel, but no rudder. It takes off, flies, and lands just fine, and this concept could certainly be scaled up to a full-scale airplane.
In many light airplanes, much of the time the rudder is used more of a "trim" control to optimize streamlining by cancelling out effects like p-factor, but is not absolutely essential. It becomes more important in crosswind landings, but some light airplanes like the Aercoupe have been built with no independently controllable rudder. Such aircraft invariably have tricycle landing gear rather than tailwheel landing gear, for greater directional stability on the ground.
In sailplanes (gliders) with long wings of high aspect ratio, adverse yaw is very pronounced and it is very important that the rudder be applied along with ailerons when entering and exiting turns. There are various design features, like differential aileron deflection, that can reduce adverse yaw.
There are two main reasons: control on the ground and efficiency in flight.
When an aircraft is rolling on the ground, the only way to control its direction is with the rudder. When a pilot both takes off and lands an aircraft they use the rudder to steer. If the aircraft had no rudder, it would likely roll off the runway.
In flight, the rudder is used to keep the fuselage parallel to the line of travel. For example, if the pilot makes a turn without using the rudder air will hit the side of the aircraft and the drag on the plane will be significantly higher.
Another cause of inefficiency in propeller aircraft is what is known as P-factor. This is a yawing of the aircraft due to asymmetrical force in the propeller causing drag. The pilot must hold down the rudder constantly to prevent this. It can become quite tiring to do so in long flights.
