I saw on wiki that a boeing 737 flys at about 38,000ft and a Concorde flys at 60,000ft. What made it possible, and advantageous, for Concorde to fly so much higher?
    $\begingroup$ As titled, this question is not a duplicate. It asks why. The question body needs help though. $\endgroup$ Commented Aug 7, 2015 at 0:58
  • $\begingroup$ @digitgopher the one marked as duplicate contains the answer to the why as well. This one is then correctly closed. $\endgroup$
    – Federico
    Commented Aug 7, 2015 at 13:55
It was necessary for Concorde to fly much higher, and not a voluntary decision. A higher cruise altitude increases the demands on the airframe (examples: Combustor size, pressurization) and is only accepted when it comes with sufficient benefits.
An airplane needs a certain wing area for realistic take-off and landing distances. Also, details like the maximum tire speed need to be observed, so the wing area must be large enough to create enough lift at low speed.
Lift is proportional to the square of airspeed and air density. The faster a plane flies, the lower the density can be to create sufficient lift. By flying more than twice as fast as a Boeing 737, the Concorde could fly at a fourth of the density by this reasoning. Air density (symbolized by the Greek letter $\rho$) halves approximately with every 5500 m of altitude increase.
However, the slender wing needed for low supersonic drag is not as efficient as the sub- / transsonic wing of a 737, so a little more density was needed for the Concorde. The 737 is designed for cruise between 8000 m ($\rho$ = 0.526 kg/m³) and 12000 m ($\rho$ = 0.312 kg/m³), and the Concorde flew between 16500 m ($\rho$ = 0.154 kg/m³) and 18000 m ($\rho$ = 0.121 kg/m³).
  • $\begingroup$ While perfectly valid, can you explain how your first paragraph relates to the question? (Note: I didn't get much sleep last night, so I may have simply missed something.) $\endgroup$
    – FreeMan
    Commented Aug 7, 2015 at 13:09
  • $\begingroup$ @FreeMan: Concorde could fly at the same altitude than the 737 it its wings were smaller. Then it could afford to have smaller combustors and a much smaller wing. Flying higher is creating a lot of problems, and was the result of the rather large wing, which in turn was required to allow Concorde to operate from existing runways. $\endgroup$ Commented Aug 7, 2015 at 13:16
  • $\begingroup$ So, A) the Concorde needed a slender wing for good supersonic performance, which B) doesn't produce as much lift at lower speeds, requiring C) a larger wing for realistic take-off/landing speeds, which lead to D) a higher cruise altitude because of E) the extra lift available at higher altitudes from the very large wing? $\endgroup$
    – FreeMan
    Commented Aug 7, 2015 at 13:31
  • $\begingroup$ @FreeMan: Yes. Airplane design can be so easy! $\endgroup$ Commented Aug 7, 2015 at 18:01
  • $\begingroup$ Makes you wonder why people go to school all those years to get some sort of engineering degree. I learned that in a couple of month's reading on a Q&A site! ;) $\endgroup$
    – FreeMan
    Commented Aug 7, 2015 at 18:09
The air is much thinner up that high and therefore there is much less drag/resistance, therefore an airplane won't heat up as much as it would going the same speed at a lower altitude, and it requires much less thrust/fuel as well (economics matter too when you have paying passengers).
  • $\begingroup$ Aeroynamic heating depends on airspeed squared. Lower density will only reduce the heat flux, but not the temperature. If an equilibrium is reached (pretty likely for an airliner which cruises for several hours), the heat flux is not a factor anymore. $\endgroup$ Commented Aug 7, 2015 at 18:07
