When I read through IFR materials online, or when I hear pilots talking about approaches, they often talk about using fixes to get to/through the approach.
Two questions (closely related):
  • Firstly, just to make sure I completely understand, what are fixes in this particular context?
  • Secondly, how are they used when a pilot is using a particular approach?
  • $\begingroup$ Related: How are airspace fixes named? $\endgroup$
    – Farhan
    Aug 4, 2015 at 16:09
  • $\begingroup$ @Farhan I...guess that's related. I mean, it is also about fixes. Though, from reading the question and answers, that's about where the similarities end. $\endgroup$
    – Jay Carr
    Aug 4, 2015 at 16:13
  • $\begingroup$ @Farhan, oh wait, I see it now. The first sentence of the question gives some very brief detail on what they are. I'm hoping for more, but that's a good start :). $\endgroup$
    – Jay Carr
    Aug 4, 2015 at 16:14
    $\begingroup$ Yes, it is only related. It is not similar or duplicate, and hence I only mentioned that. $\endgroup$
    – Farhan
    Aug 4, 2015 at 16:15
    $\begingroup$ This one is very closely related and may answer your first question. $\endgroup$
    – Pondlife
    Aug 4, 2015 at 16:32
4 Answers 4
What a fix is has been answered here but for now let's just say it's a known location that a pilot can navigate to if he has the right equipment. Fixes are shown on various charts and approach plates.
As for using those fixes on an instrument approach, there are lots of variations and details but again, let's ignore most of that for now. The basic concept is very simple:
  1. Fly to an Initial Approach Fix (IAF)
  2. Fly to other fixes as needed to execute the approach
  3. Land (or go missed)
For example, here's the RNAV (GPS) 36R approach at KHSV:
KHSV RNAV (GPS) 36R
You can see at the bottom of the map portion of the plate that both MASHA and FEWER are IAFs, so that's where the approach starts. Let's say you're approaching from the south-west and you've already descended to a reasonable altitude for starting an approach, following a STAR or vectors from ATC.
ATC says something like "N12345 proceed direct MASHA, cleared for the RNAV 36R approach". That means that you are now cleared to execute the approach as shown on the chart, with no further instruction from ATC (although they might have vectored you towards the IAF initially).
The chart tells you that at MASHA you need to be at at least 3000ft MSL so you simply fly there at or above that altitude. Since it's a GPS approach, you load it and activate it in your GPS unit, and you can follow the GPS track to MASHA.
After MASHA, the next fix is ENIKY and the GPS track will lead you east to that fix (which is a heading of 091° from MASHA). The profile view at the bottom of the plate shows that you must still be at or above 3000ft at ENIKY. Then you turn left to 002° and fly to UJOTY, where you must be at or above 2700ft. Then you continue to GEPDE at or above 1180ft. Then you land :-)
Of course, I'm ignoring a huge amount of detail here - like everything else printed on the approach plate! - but since this question is about fixes the main point is that they're simply a series of waypoints that you fly over (or past) to get to the runway. And obviously you also have to control your altitude as you descend, but the altitude is defined by the approach procedure, it isn't part of the definition of the fix itself. The same fix can be used in multiple approaches: MASHA and FEWER are also the IAFs for the RNAV (GPS) 36L approach).
Even though different approaches define and use fixes in different ways, the basic idea is always the same: just fly from one fix to the next until you get where you're going.
A fix is a point is space that defines a segment of an approach. You can think of it like an intersection on a street map that defines the approach. So when someone says "Take Jones Road to Main Street and Turn left. Then go one block and turn right onto Broadway" you can think of Jones & Main and Main & Broadway as two fixes.
In aviation terms such as the approach below, there are fixes named DIVEC, PONKE, WETOR, ROKMO, HEMAN, DUYET, NEPIC, and I-SFO, which the pilot follows to get to the intended airport. plate.
  • $\begingroup$ How does that work into a particular approach though? Do airports usually have a fix at the head of an approach? Or do you get to the fix and expect vectors? Does it change depending on the class of the Airport? $\endgroup$
    – Jay Carr
    Aug 4, 2015 at 17:56
  • $\begingroup$ In addition to the runway approach plates like rpb posted a large airport like SFO has published standard terminal approach route [STAR] plates. There will be several of them depending on which direction you are coming from. One of these will be filed as part of the flight plan. These will give you a series fixes to follow as you near the airport. There are instructions specific to which runway you are assigned and will tell you at what point you should expect to begin receiving vectors from ATC. $\endgroup$
    – TomMcW
    Aug 4, 2015 at 19:22
  • $\begingroup$ Example of a STAR: airnav.com/depart?http://155.178.201.160/d-tpp/1508/… $\endgroup$
    – TomMcW
    Aug 4, 2015 at 19:26
Fixes are in some ways like VRPs (visual reporting points when VFR). You fly to a fix, then fly a particular pattern away from the fix in a very tightly controlled, direction, speed and height designed to get you to close to the threshold at the correct speed and height. The exact pattern will be different depending on the type of approach you are using - each runway at an airport may have more than one, although depending on runway in use, only one approach will usually be in use at one time unless say you have an ILS failure in the aircraft and have to use an alternative. I'll let somebody who is instrument current explain an example, they will do a much better job than I can right now.
A fix is a virtual position that helps aircraft maintain their flight plan. It is usually defined as the intersection (in the geometrical sense) of two VOR radials, but other navigational aids such as GPS or even radar can be used to identify one of these positions.
The most basic use of fixes are to define a flight path using one or more fixes. The flight path is usually direct between two fixes but there are exceptions like the DME arc. Not only do fixes identify a flight path, but they can also be used to denote a position where a new altitude can be descended to. For example, on an approach an aircraft may have to maintain 7000 feet as is the case with DIVEC, but may descend to 6000 feet after passing DIVEC on the way to PONKE. In short, fixes are used to establish both the horizontal and vertical flight paths of aircraft.
approach plate
