What advantage does the "blisk" or "bladed disk" type rotor have over the usual rotor system?
2$\begingroup$ en.wikipedia.org/wiki/Blisk#Advantages $\endgroup$ – mins Jul 26 '15 at 12:39
3$\begingroup$ As @mins points out, this question shows a pretty clear lack of research. $\endgroup$ – egid Jul 27 '15 at 0:23
Since the blades and rotor disc are a single piece, there are no additional fittings (bolts, screws etc) to attach the blades reducing complexity and weight. The blade root joints are also a source of failure through manufacturing defects and fatigue cracks.
The disadvantage is that any damage to a blade requires the entire assembly to be replaced rather than a single blade.
"Module weight savings of 15% and improved aerodynamic efficiency", according to Rolls Royce.
From a manufacturing point of view, replacing literally hundreds of sub-components (individual blades, etc) with a single part has obvious advantages - though of itself, that wouldn't give the customer any benefit if it didn't also reduce weight and/or improve performance.
$\begingroup$ If something is advantageous to the manufacturer, one would expect that to lead directly to a less expensive part for the customer. $\endgroup$ – David Richerby Jul 26 '15 at 20:06
$\begingroup$ You might, I wouldn't. Products are priced according to profit, demand etc, not according to the cost to produce. $\endgroup$ – Jon Story Jul 27 '15 at 13:12
The above answers give very good technical reasons for blisks. Less parts means less rotating weight which has a high impact on overall weight.
However, the technical benefits are not the only considerations. As engines age eventually they are worth more in parts than as an engine and the parts are salvaged and sold. The compressor blades can bring in a tidy sum. However some will have erosion and other nicks that will not meet the manual limits for returning to service. So not 100% of the parts removed from a compressor can be salvaged and sold. There are several thousand blades in a modern high pressure compressor. This salvage market is competition to the aero engine manufacturers. The manufacturers would rather you buy a new part from them than a used part from someone else.
Aircraft engines follow the same economic model as razor blades. The initial purchase may be sold at a loss but the replacement parts will be profit drivers.
A salvaged Blisk will have airfoils with erosion and or nicks and dents on the airfoils (this can happen after only a few hours of operation) So the blisk assembly will not be able to be inspected serviceable. The engine operator will need to send the part to the Engine Manufacturer for a proprietary repair. This gives the engine OEM a better control on the used material on the market.
In conclusion, less weight is always good but the blisk also provides an opportunity for the engine OEMs to ensure that they sell parts and make a return on their initial investment.
2$\begingroup$ Do you have much evidence to support this? I was under the impression many engines are actually rented rather than purchased so it's the OEM's loss if parts can't be refurbished. Also with the stricter and stricter rules around emissions every bit of weight that can be saved counts and 15% of a large blisk is a considerable amount of weight! $\endgroup$ – Notts90 Aug 7 '17 at 18:09
1$\begingroup$ @Notts90, you are under the right impression. RR has switched to renting engines. So it is unlikely there are any Trent XWBs not owned by RR and therefore any point about competition from refurbished part resellers is moot. $\endgroup$ – Jan Hudec Aug 7 '17 at 19:38
