A coaxial rotor helicopter is connected to the same engine and has the advantage of anti-torque and a +/- 25% increase in lift. My question is if a coaxial ducted fan connected to the same engine would also have a +/- 25% increase in forward motion ?
Part of the gain of coaxial rotors on a helicopter is not having to power the tail rotor (IIRC it takes ~10%). So for contra-rotating propellers and fans, which don't need a tail rotor, the advantage is smaller, about 6–16% [1].
Now ducted fans (assuming as used in turbofan engines) usually contain stators. These do not stop the rotation of the flow (that takes away the energy) completely, but they do reduce it significantly and with much lower complexity. The remaining possible gain would probably be at most couple of percent and that is likely not worth the increased complexity and weight of additional gears. Don't forget that turbofans run at significantly higher rotation speeds than propellers.
  • $\begingroup$ @KorvinStarmast, I am not. I am comparing contra-rotating rotors and contra-rotating propellers. $\endgroup$
    May 9, 2017 at 7:15
  • $\begingroup$ @KorvinStarmast, the question is about whether the advantage contra-rotating rotors (on helicopters) have applies to fans (in airplane turbofan engines). So I am first saying what that advantage is, and then that it does not apply to propellers and fans. $\endgroup$
    May 9, 2017 at 12:45
  • $\begingroup$ @KorvinStarmast, because propellers are between rotors and fans. $\endgroup$
    May 9, 2017 at 18:40
