10
If a 35 year-old pilot were issued a 1st class medical on January 15, 2012, am I correct that that pilot would be able to exercise privileges requiring a 1st class medical until January 15, 2013? Or would they extend until January 31, 2013? The chart in 14 CFR 61.23 mentions something about it expiring on the last day, but I can't find that exact language anywhere but in the header row of the reference table.
Additionally, after the 1st class medical certificate expires, does it not afford the pilot the privileges of a 2nd class medical for the 60 months listed in 14 CFR 61.23? I'm looking for the part of the FAR that explains how medical certificates of a higher class afford the privileges of a lower class after their original designation period expires.
16
A first class medical issued to a 35 year old pilot on 15 Jan 2012 will let that pilot:
  • exercise privileges of an ATP certificate until 23:59 31 Jan 2013
  • exercise privileges of a commercial certificate until 23:59 31 Jan 2013
  • exercise privileges of a private, recreational, student or CFI certificate (if the CFI is acting PIC) until 23:59 31 Jan 2017
Your first class medical is always a first class medical -- you don't get private pilot privileges for 5 years because a first class medical grants third class privileges, rather you get private pilot privileges for 5 years because that is what a first class medical grants you.
These durations are from the table of 61.23 (d). You don't see this language in the text above the table because they are not concerned with the duration of the privileges but only the minimum required medical class for specific operations.
For example, 61.23 (a)(2)(ii) says you must hold at least a second class medical to exercise the privileges of a commercial certificate and 61.23(d)(1)(iii) and 61.23(d)(2)(i) list the duration that each of an first and second class medical can be used to for this purpose.
  • $\begingroup$ I especially appreciate your point about a first class medical always being a first class medical, but the specificity about the times on privileges. Thanks, it clarified everything that I wanted to make sure I understood clearly. $\endgroup$
    – ryan1618
    Jul 20, 2015 at 19:47
I'm a bit unsure what you're looking for, because the answers to your questions are all in the table that you already found. But anyway, the medical would expire for first-class use on Jan 31 2013. The language is in the table header, as you already noted (my emphasis):
Then your medical certificate expires, for that operation, at the end of the last day of the 12th month after the month of the date of examination shown on the medical certificate
For second-class privileges - by which I assume you mean commercial pilot privileges - the medical would also expire on Jan 31 2013, as per the third row in the table, which covers these privileges:
a commercial pilot certificate or an air traffic control tower operator certificate
The only way you can use it for 60 months is for the following privileges:
a recreational pilot certificate, a private pilot certificate, a flight instructor certificate (when acting as pilot in command or a required pilot flight crewmember in operations other than glider or balloon), a student pilot certificate, or a sport pilot certificate (when not using a U.S. driver's license as medical qualification)
