Reading about aircraft carrier operation turns out that carrier operation relies a lot on catapult and carrier itself turns into wind with high rev on propellers. This generate as high wind speed as possible to make a takeoff easier for fixed wing aircraft.
My question is in the absense of carrier's own speed and turning into the wind, would fixed-wing carrier-based aircraft be able to takeoff using catapult and its power alone?
  • $\begingroup$ If they don't carry a full load of ordnance and fuel, why not? Adjust the minimum speed appropriately by reducing take-off mass, and you can take off with the catapult, but without headwind. $\endgroup$ Jul 15, 2015 at 7:38
  • $\begingroup$ If the carrier can't turn into the wind, this certainly depends entirely on the wind speed and direction. $\endgroup$
    – JulianHzg
    Jul 15, 2015 at 10:55
  • $\begingroup$ Perhaps the carrier will at the very least need to maneuver to face into the wind. I can't see a fighter landing or taking off in a crosswind very easily (relatively narrow wheel separation on main landing gear). $\endgroup$
    – ALAN WARD
    Jul 15, 2015 at 22:19
  • $\begingroup$ This was covered at length in Tom Clancy's Debt of Honor. Also, carrier aircraft can always do as strategic bombers and spy planes do: launch on bingo fuel, and immediately hit the tanker. $\endgroup$ Mar 14, 2022 at 19:29
Aircraft carriers using STOBAR (the skyramp) always need to maintain a speed of about 55kmph in order for the aircraft on them to take off. This is done to generate enough windspeed on the deck to assist the aircraft to take off. And STOBAR system already hampers the carrying capacity of aircraft, so for takeoff from a STOBAR carrier at rest, a further reduction in takeoff weight of the aircraft would be required to generate enough lift for the aircraft to take off at such low speeds. This reduction in weight would depend on the aircraft carrier and the aircraft as such and might create scenarios where this is entirely not possible.
For Aircraft Carriers equipped with CATOBAR, the conventional steam piston drive which is used to catapult the aircraft provides approximately 95 MegaJoules of energy to accelerate the aircraft to speeds where it can takeoff safely. Hence the arguments stated about the STOBAR carriers can be sequentially applied to this class as well. But recent Electromagnetic Aircraft Launch System provides around 122 MegaJoules of energy to accelerate the aircraft. Given the extra amount of energy available to accelerate the aircraft at higher speeds, it is quite possible that it is going to be easier for the aircraft to take off from a static aircraft carrier equipped with electromagnetic catapults when compared to the aircraft carriers equipped with convention steam piston catapults. But the exact details for the feasibility of this idea would be a matter of national interest and might not be available online.
Also, one should not ignore the extra amount of stresses that an aircraft would have to face while taking off from a stationary aircraft carrier as it would have to accelerate to a higher speed at the same available length of the runway and hence this might prove detrimental to the lifetime of the aircraft.
Edit:
Under research technologies such as Ground Carriers, if implemented would also assist further in reducing the weight of the aircraft and hence make it easier for the aircraft to take off from carriers at much lower speeds.
  • $\begingroup$ Given the extra amount of energy available to accelerate the aircraft at higher speeds, it is quite possible that it is going to be easier for the Aircraft to take off from a static aircraft carrier equipped with electromagnetic catapults -- Pilots (and equipment) don't like sudden changes in velocity that much. I'm pretty sure it will be possible, but SOP will probably still be steaming into the wind to reduce the acceleration required to reach a flying airspeed. $\endgroup$
    – voretaq7
    Jul 15, 2015 at 19:29
    $\begingroup$ "Aircraft carriers using STOBAR (the skyramp) always need to maintain a speed of about 55kmph in order for the Aircrafts on them to take off." That doesn't seem to be true. The British Invincible class carriers had a maximum speed of around 52kph and used STOVL. That would leave the carrier unable to launch aircraft if it couldn't reach its maximum speed. $\endgroup$ Jul 15, 2015 at 19:33
    $\begingroup$ @DavidRicherby I think Victor's statement refers primarily to conventional aircraft using the "ski jump"; The Russian Navy launches Su-33s this way, and the Indian Navy has a few skyramp launchers for the HAL Tejas. When using STOVL aircraft and a skyramp like the Sea Harriers aboard the Invincible, you don't need as much airspeed because you're using thrust for lift. Those Harriers could, in an emergency, do a pure vertical takeoff, but that uses a lot more fuel and has a lighter MTOW so they prefer the ramp (which works for a Harrier even when the carrier is at idle). $\endgroup$
    – KeithS
    Jul 22, 2015 at 16:17
Carrier takeoffs depend on three factors to establish aircraft airspeed. Wind velocity (means speed and direction), aircraft speed, and ship speed. That is why most carriers are travelling into the wind at 35 mph or more. If a catapult developed 150 mph speed, and the wind speed is 10 mph, and the ship is heading into the wind at 10 mph, an aircraft with a 170 mph go/ no go threshold would be pushing the envelope. This is why most carriers like a 20 to 30 knot bow wind over the deck. It makes take offs possible and landings far easier.
In theory, a 20 knot wind properly aligned and 150 mph catapult could launch some fixed wing aircraft.
USS Saratoga launched all aircraft that it could while sitting in Athens harbor August 15, 1971. The first day in port, I was on night shift the night before and my buddy came to wake me up and when I got up I noticed the ship was pitched enough that I was walking uphill. A huge salt water hose broke (about 36inches maybe bigger) and they launched A/C to get weight off the ship. We were about 1 mile from the shoreline. A F-4 pilot made his last carrier takeoff that day as he barreled rolled at a couple hundred feet above the beach at the shoreline.
  • $\begingroup$ Cool story! I assume the got the leak stopped & water pumped out okay? Welcome to Av.SE! $\endgroup$
    – Ralph J
    Mar 15, 2021 at 18:18
    $\begingroup$ So why was that the the pilot's last carrier takeoff? Because he broke regulations by doing the barrel roll and got demoted? Because he was leaving anyway and figured he might as well show off? Or because his barrel roll ended in the water? $\endgroup$
    – jamesqf
    Mar 16, 2021 at 0:47
