The question is basically up there in the title; I need a default value for an app that won't do anything. A friend suggested XXX, but I'm sure there must be one reserved specifically for that purpose? ;-)
Is there a code that's used in the travel industry to denote "enter city code here" without actually being mapped to a metropolitan area/city/airport? I'm guessing it might be one beginning with Y... :)
    $\begingroup$ The ones starting with Y usually belong to Canadian airports $\endgroup$
    – Blackbird57
    Jul 6, 2015 at 21:51
    $\begingroup$ BTW, pnuts, just found HHH is taken... @Blackbird57, looks like it might be one starting with Z, actually, if there is one: "'Z' was reserved for special uses" - skygod.com/asstd/abc.html $\endgroup$
    – Christian
    Jul 6, 2015 at 22:26
  • $\begingroup$ Apologies all - BIG **** in a simple formula :$ Yes GGG, HHH, PPP, TTT and YYY already exist so my conclusion was wrong also. (Mind you, seems poor data control.) $\endgroup$
    – pnuts
    Jul 6, 2015 at 22:39
  • $\begingroup$ @Christian Fascinating link but (dare I say it) I am not sure "Z" was reserved for special uses" is exactly what you are after. Bear in mind there seem to be at least 35 IATA airport codes starting Z. $\endgroup$
    – pnuts
    Jul 6, 2015 at 23:16
    $\begingroup$ Bad design, you should not enter anything there by default, either put an explanation next to the field or as @tom suggested put some ghost value. Also, you should let the user type the whole city/airport name and then a dropdown shows with a list of airports matching the input, not everyone knows airport codes. $\endgroup$ Jul 7, 2015 at 1:07
11
Good question, no good answer.
In the ICAO system, the identifier ZZZZ is reserved by that agency to designate on flight plans that the airport does not have an ICAO code assigned (not all airports do; for instance Qualicum Beach Airport in British Columbia is TCCAA registered and has TC and IATA codes but no ICAO code). There is no specific combination of alphanumeric characters reserved to mean "airport not specified"; if the flight plan does not specify an airport at a particular stop, the ICAO code field will be blank (which is valid in many circumstances in general aviation; float planes can set down on any relatively calm body of water, while bush pilots routinely fly out to a dot on the map in the literal middle of nowhere to deliver supplies or people to an established but temporary campsite).
XXXX is an unassigned but unreserved ICAO code that a few websites seem to be using for testing and demo purposes; FlightStats has a page for this code but the data is sparse and nonsensical.
The IATA system labels practically all registered airports (primarily ones of interest to commercial flight, but all FAA-registered airports have a three-character code that have, with few exceptions, been adopted verbatim by IATA). The IATA has no specially reserved code for "not specified" or any other special case. The code ZZZ is currently unassigned, and is used informally by bush pilots to indicate an "unregistered" landing area similar to the ICAO system (though as IATA labels more airstrips especially in North America, this code is used more specifically for unimproved landing areas, which are common in backcountry areas of the Plains States, Northwest and Alaska). But again, that still indicates an entry was made.
If you are writing a computer system for flight planning and you want a string value to indicate that the user has not specified an IATA identifier, the safest are null, the empty string, or three spaces. "000" is probably also safe, as IATA does not and likely will never use three zeroes for any valid identifier, and OOO is also not assigned. The code "ANY" is reserved for Anthony Municipal in Kansas, but the code "NON" is not currently assigned (though with no guarantee it will remain so). XXX, YYY and ZZZ are also unassigned but other repetitive letters are.
