Can a plane lift off the ground at the point when there is the same amount of lift as weight? Or does lift have to be greater?
1 Answer
Yes they can, in fact aircraft regularly lift off the ground when lift is less than weight. They achieve this by rotating the nose, which provides a vertical component of the thrust vector. See the excellent answers to this question for a detailed explanation.
