I've been recently introduced to the world of mini aircraft, specifically, quadcopters - building them, flying them, calibrating them (apparently, it's such an important point that it deserves its own place on the list :) .
I'm about to finish building my own quadcopter (as soon as I can get a power distribution board - hard to find, it seems), and my hands are itching to try and fly it as soon as possible. I've learned a lot about how planes / helicopters / quads fly while in the process of building one. But maybe I haven't not learned enough about it, and was hoping you can help me with one question I have.
I think I've learned enough about the types of propellers used in these vehicles, power requirements, controllers, calibration, and whatnot. While searching about these things on the net, and asking a few friends about their experiences, a thought came into my mind:
Wouldn't be nice if I could, basically, scale all the components of this small, 330mm vehicle I'm building, to make something bigger?
I mean, bigger as in big enough to carry one, maybe 2 people around ?
Can I really say "hey, let's build a frame X times larger, with stronger materials, lets get 4 motors X times bigger, let's use 4 X-sized variable pitch propellers" and so on and so on, and actually be able to build a quadcopter able to carry people in it?
(Yes, yes, I know I'm basically saying "let's build an actual size helicopter, but with 4 propellers instead of one".)
Do you think this is a feasible approach to build such a thing? Is it even remotely possible? Have you had any experience doing such a thing? Any comments will be highly appreciated.
  • $\begingroup$ Well, there are a lot of concerns with doing this, though it still may be technically possible. You should check out the other question cpast linked for a further discussion. And, if you have more specific questions regarding quad copters, please feel free to post them here :). $\endgroup$
    – Jay Carr
    Jul 1 '15 at 22:01
Ducted fan designs like quadcopters are actually somewhat simpler in some ways to design and build than single-rotor helicopters, because the nature of the design means that the rotors don't need the complex mechanical linkages of a helicopter's main rotor; the four rotors can control pitch and bank simply by varying RPM, and so each one can be a fixed-pitch propeller. The design becomes more stable with a variable-pitch rotor design as the possibility of varying thrust with a constant rotor speed reduces unwanted roll moments from gyroscopic forces, but that throws the simplicity argument out the window (and helicopters have potential roll problems during throttle-up as well, some of which had to be solved before the thing could even take off).
Yaw is a little trickier, and one potential limiting factor to scaling up the design. The problem is that with all four rotors in a fixed vertical orientation, which is the simplest mechanically, there's nothing to produce lateral thrust to turn the aircraft around the Z-axis (straight up from the ground through the 'copter in level flight). Options include:
  • One laterally mounted fan. Simple to design, but you're adding one more fan to a design with a lot of high-speed spinning parts already, and the fan would either have to stop and start in opposite directions very often (easy with a little DC motor and plastic fan on a model, much more difficult when scaled up), or the blade pitch would have to be variable, to allow variable thrust to either side while the rotor turns in one direction) which increases complexity again.
  • Two lateral fans, one facing each direction; by varying their power (they'll probably both be spinning at a low idle while in flight) you provide yaw. Advantage is mechanical simplicity of each fan, disadvantage is having not four, not five but at least six fans, reducing "mean time between failures" of at least one of them increasing required maintenance that much more to ensure it doesn't happen in flight.
  • Arranging the main four rotors such that each rotor rotates the same way as the rotor in the diagonally opposite corner, and opposite the other two. By reducing the power of fans rotating in one direction and increasing the power of the other, you can induce yaw as the craft will yaw opposite the direction of the faster rotors due to the torque imbalance, without causing the aircraft to also pitch or roll as the total forces in those planes stays constant. The advantage is reducing the need for additional rotors; the four main rotors can provide motion in all three planes. The disadvantage will be slower yaw rates and increased maximum thrust requirements of each rotor basically allowing any two rotors to maintain required lift (a good requirement to have, not a great one to rely on everyday).
  • Putting the main rotors in tilt mounts and tilting them in rotationally-symmetric ways to induce yaw. It's an intuitive way to induce yaw, and the same tilt-rotor system would also reduce the amount of pitch required of the full aircraft to produce forward motion; just tilt the rotors and keep the fuselage level. Disadvantages include increased mechanical complexity, and the gyroscopic precession induced by trying to tilt a rotating mass which can cause the craft to tumble off its lift vector.
Other potential problems with the quad-rotor design include ensuring reliable power distribution (including maintaining some control if a rotor or an engine gives up completely), the lower inertia of the smaller rotors reducing the effectiveness of autorotation in an emergency, the need by many potential customers to fold the design up more compactly than its flight configuration, and the inherent fragility of the design with ducted fans on pivots in the corners of the aircraft, making it more vulnerable to fatal damage in "combat environments" (translated; everyone not on your side shooting whatever they have at you). Because the U.S. military has been a major customer of rotary-wing aircraft and a primary source of R&D funding, the survivability of the design against things like small-arms fire that a helicopter can typically take a few hits from is a definite point of consideration.
The last problem plaguing the quadrotor is more fundamental, and it is the lack of an answer to this simple question: what can a "full-size" quadrotor aircraft do that cannot already be done as effectively and cheaper with a traditional helicopter? The primary reason quadrotors make good UAVs is that it's easier for a computerized fly-by-wire system to keep them stable, but that is their only advantage to date compared to a single-rotor helicopter, so until the aircar becomes a serious legal and engineering possibility and people want a rotorcraft that is as easy to fly as a car is to drive (or at least easier than a helicopter where you pretty much cannot let go of the cyclic, ever), the quadrotor will likely remain small-scale.
  • $\begingroup$ Fantastic answer. Thank you. Just a little comment: Isn't bullet point 3) exactly how rotors are arranged in a quadcopter, by design? $\endgroup$
    – Izhido
    Jul 1 '15 at 23:49
    $\begingroup$ Maybe not by design (meaning it's an absolutely essential design decision); the copter would fly stably with the rotors on each side rotating the same and opposite the other side (a dual twinrotor setup), but you would need an alternate method of yawing. That opposing-corner arrangement is a problem in itself for scale-up, because the amount of yaw produced even by all four rotors is much less than what you get with the single rotor of a chopper (for a number of reasons, primarily that the center of lift, center of mass and axis of rotation are all very close in a chopper) $\endgroup$
    – KeithS
    Jul 2 '15 at 15:35
