11
Wikipedia says that because of the area rule's impact on wave drag:
aircraft have to be carefully arranged so that at the location of the wing, the fuselage is narrowed or "waisted", so that the total area doesn't change much.
This much makes sense to me. Though it's a bit difficult to tell, I understand that in the picture supplied there, the green circle toward the front of the aircraft is intended to have roughly the same area as the blue circle and lines through the wing cross-section:
Wikipedia's area rule example plane
All images from Wikipedia unless otherwise noted
This is more clear in the picture of the F-106 Delta Dart where one can easily see the Coke bottle waist where the wings near their widest:
F-106!That's an awesome picture! You could stare at it all day, couldn't you?
Peter Kämpf even provides a nice explanation of the area rule in his answer here including a drawing from the Junkers patent on the subject:
Junkers patent picture
Image posted by Peter in his answer, referenced above
In this image, I can see how the areas through several lines across the fuselage, wings & engines are all intended to be (roughly) equal.
What I don't understand is how this is applied to airliners like the Airbus A380 which they say is:
showing obvious area rule shaping at the wing root
in reference to this image:
An A380's soft, vulnerable underbelly
To me, it appears that the cross-section at the wing root consists of the same area at the front of the plane (roughly behind the cockpit appears to be where maximum diameter is achieved), plus the area of the wing root, plus the area through the wing, plus the area through a pair of engines (depending on exactly where you make the cross section). As I see it, there's no slimming of the body to make the area through the wing cross section equal to the area of the cross section just behind the cockpit.
This shot from above of another A380 shows that there is no Coke bottle waist near the wings:
A380 from above
Am I not seeing this correctly, or do I not understand the area rule correctly?
  • $\begingroup$ I checked your link, but I do not see any mentioning of the area rule. Are you sure the link is correct? Furthermore, I agree with your point, and to me it seems that the area ruling is most obvious from the large pods on the trailing edge, rather than something on the wing root. $\endgroup$
    – ROIMaison
    Jun 25, 2015 at 19:33
  • $\begingroup$ @ROIMaison: Which link do you think is incorrect? To me it looks like all the links that I expected to be about area-rule are about area-rule. $\endgroup$
    Jun 25, 2015 at 19:37
  • $\begingroup$ @ROIMaison not sure which link you're referring to, but the first one goes directly to the Wiki Area Rule page... $\endgroup$
    – FreeMan
  • $\begingroup$ Sorry, I misread, I thought the A380 article would talk about the area ruling of the A380, but it was the area ruling article. Please disregard my comment. $\endgroup$
    – ROIMaison
    Jun 25, 2015 at 19:41
    $\begingroup$ This picture seems to better show some contours aft of the wing. $\endgroup$
    – fooot
    Jun 25, 2015 at 19:43
First of all, not the area should be equal, but the area gradient along the direction of flow should be shallow. The minimum drag with a given volume can be achieved when the area distribution is that of a Sears-Haack body. Ideally this rule applies only at Mach 1, and once you go faster, the cross sections which matter are those along a Mach cone, not those of the aircraft's cross section.
For subsonic flight, the penalty for neglecting the area rule is small; it only matters when local flow is supersonic ahead of a contraction of the contour of the aircraft. Subsonic flow would decelerate, whereas supersonic flow will accelerate further and result in a drag-intensive shock downstream. Adding something to fill up the contraction will reduce the pressure gradients and ideally avoid the shock. By this, area ruling will help to shift the onset of the Mach-related drag rise and enables airliners to cruise a little faster. Honestly, I cannot see the "obvious" area rule shaping on the A380 - to me this is classic subsonic aerodynamics which tries to avoid sharp pressure gradients in the area of the wing airfoil's rear loading. Especially the outer engine pylons could be done better, but I digress.
For airliners, it is much more important to have a constant fuselage cross section, which makes stretching the fuselage simpler and is much easier to build. Area-ruling the fuselage simply is not worth it (yet) when your maximum cruise speed is just Mach 0.85. It is enough to add some Küchemann bodies to smooth out pressure gradients.
Below is a comparison of a swept wing at Mach 0.9, on the left clean and on the right with Küchemann bodies. Note the massive flow separation on the left wing, whereas the flow pattern on the right wing shows attached flow.
Mach 0.9 wing comparison
Mach 0.9 wing comparison (picture source)
  • $\begingroup$ So the 'pods' at the wing root are really only there to smooth the increase in cross section as the leading edge of the wing comes into the cross section? Similar to the wing strakes on an FA-18. $\endgroup$
    – FreeMan
    Jun 25, 2015 at 19:59
    $\begingroup$ @FreeMan: No, it is about avoiding a steep pressure rise in the rear part on the lower side of the wing. There the airfoil has plenty of camber and is thinned rapidly, in order to gain lift and allow to have high-camber flaps. Without the bump in the fuselage fairing and the flap track fairings, the flow can separate there at low angles of attack. The general concept is to avoid adding two pressure rises, that of the wing and that of the fuselage, at the same lengthwise station. $\endgroup$ Jun 25, 2015 at 20:05
  • $\begingroup$ I think I follow you. However, that doesn't (in my mind), track with what the Wiki article says. Have I misinterpreted the Wiki article, is it wrong, or am I just not putting all the pieces together? $\endgroup$
    – FreeMan
    Jun 25, 2015 at 20:10
  • $\begingroup$ The belly fairing is there to prevent super velocities, it's not related to the area rule $\endgroup$
    – ROIMaison
    Jun 25, 2015 at 21:10
    $\begingroup$ @FreeMan: The Wiki article sounds as if the area rule is the only thing to consider in design. The rear part of the airfoil is where the lowest flow speed can be found, and this is the part that needs area ruling? Sounds odd, right? And bulging fairings right behind the wing root are not exactly "coke-bottling" the fuselage. In truth, both area ruling and decoupling pressure rises are related concepts which lead to the same contours. The Wiki article could be improved if it would also mention this. $\endgroup$ Jun 26, 2015 at 3:34
On airliners it is applied via the use of these sharp pods under wings.
A coke-bottle-like fuselage would be extremely impractical for internal arrangement and cargo loading, so it is not done on airliners even though it could probably improve the efficiency a bit.
What is done is:
  • The engines shifted ahead of the wing help smooth out the increase of cross-sectional area around the wing leading edge.
  • The enlarged flap track fairings, a.k.a. anti-shock bodies help smooth out the decrease of cross-sectional area around the wing trailing edge.
  • $\begingroup$ So the idea is to increase the cross section (or frontal area) as slowly as is reasonably possible (i.e. the front of the engine nacelle is going to happen, and you can't really stretch it fore/aft), not necessarily to keep it constant from front to back? $\endgroup$
    – FreeMan
    Jun 25, 2015 at 19:48
    $\begingroup$ @FreeMan: Yes. Because that is what the area rule says: that the cross-section should change smoothly. $\endgroup$
    Jun 25, 2015 at 19:50
Here are a couple of oil flow visualization pictures. Presumably they are taken at the same Mach number and lift coefficient. The left hand picture appears to show the upper surface of the wing with flow separation where the shock meets the surface. The airfoil sections probably pre-date supercritical designs. The right hand picture shows the application of Kuchemann carrots (or Whitcomb fairings). The flow appears to be shockless. enter image description here
The lower picture shows application of these fairings to the Convair 990. I think I'm right in saying that supercritical airfoil sections, which are designed to weaken the shock, eliminate the benefit of these fairings.
It's not clear to me that the flap track fairings on the A380 (and many other aircraft) have the same (or similar) effect seeing as the flow on the lower surface of the wing is subcritical at just about all operating conditions, as Peter Kampf points out. His analysis implies that the benefit is not due to transonic area ruling, but to other aerodynamic effects, and I'm sure he is correct.
