I have seen many photos with those sensors attached to the test aircraft, Can you provide why they are used and what do they measure?
Here is another example on SuperJet:
Sign up to join this communityI have seen many photos with those sensors attached to the test aircraft, Can you provide why they are used and what do they measure?
On the super jet that's a pitot tube rather large but still it's a testing aircraft. Aircraft's use pitot tubes to measure airspeed. The example, from an Airbus A380, combines a pitot tube (right) with a static port and an angle-of-attack vane (left). Air-flow is right to left. A pitot (/ˈpiːtoʊ/ PEE-toh) tube is a pressure measurement instrument used to measure fluid flow velocity. And so on, The basic pitot tube consists of a tube pointing directly into the fluid flow. As this tube contains fluid, a pressure can be measured; the moving fluid is brought to rest (stagnates) as there is no outlet to allow flow to continue. This pressure is the stagnation pressure of the fluid, also known as the total pressure or (particularly in aviation) the pitot pressure. Go here, for evidence.
