So it is my understanding that on most commercial jets, the airline has a choice of multiple engine types, such as GE or P&W, etc. My question would be why an airline would choose one type over the other. Also if there is a "better" choice, why would the airlines choose one of the others?
  • $\begingroup$ good question - was wondering the same after a recent question on engine costs seemed to suggest large differences on list prices (limited data). $\endgroup$ Jun 19, 2015 at 21:23
  • $\begingroup$ Similar question: What are the advantages of the Airbus New Engine Option (NEO) program? $\endgroup$
    – fooot
    Jun 19, 2015 at 21:47
  • $\begingroup$ Seems like obvious considerations would include: maximum thrust (and its effect on maximum payload), fuel burn, weight, price, reliability, maintenance costs, financing options, ... With all these trade-offs, there's no particular reason why one engine should be objectively "better" than another. $\endgroup$ Jun 20, 2015 at 16:12
  • $\begingroup$ I have no idea, but I would guess the primary consideration is existing maintenance capabilities for one or the other. $\endgroup$
    – falstro
    Jun 21, 2015 at 9:22
Power
Some models are different in power, a consideration if you intend to operate hot and/or high, or heavy. Otherwise that extra power is mostly fuel-inefficient.
Competition
In situations where two or more alternatives are available, there's healthy competition. Engines are around 25% of the cost of a new aircraft, so there would be a big money to gain when airlines bulk order from a certain company.
Boeing took this a step further on the B787 where it's easier than ever to switch the type of engine to prevent this type of 'vendor lock-in'. Historically, it was very difficult to switch due to the technical complexity in these systems.
Customer Relationship
If an airline has good contacts with a manufacturer and know how they work, they may prefer to opt for that comfort when considerable money is on the line.
Part Commonality
The more type of the same engine you operate, the better economies of scale you achieve. This is especially important as substantial maintenance work is concentrated around the engines.
This made for instance American Airlines store Boeing 757 aircraft that it got through a company acquisition that did not have the same engine type as the remaining fleet.
  • This thinking is not limited to your company, but for instance within a group of companies, as heavy maintenance is often centralized.
  • It can even apply across types. For instance, Korean Air ordered 787s and 747-8 both with GEnx engines. To quote GE Aviation on the two slightly different engine types:
    The -2B contains an identical core and similar materials as the -1B, delivering synergies for mixed GEnx fleets
  • $\begingroup$ Thanks for the detailed answer! Looks like it is an airline specific business decision more than anything. $\endgroup$
    – woakley5
    Jun 22, 2015 at 0:01
  • $\begingroup$ Part commonality sometimes work in the opposite way, when you don't want your company to be at mercy of one manufacturer. $\endgroup$
    – Agent_L
    Jul 4, 2016 at 14:15
