I read this while I was preparing for my knowledge test:
The heading indicator is not direction-seeking. It is important to check its indication frequently and reset it with reference to the magnetic compass.
and I am doing this all the time during flight time.
Why don't small aircraft manufacturer make the Heading Indicator magnetic instead of gyro?
  • $\begingroup$ What would you do when flying in an area of magnetic unreliability? $\endgroup$
    – Vikki
    Jan 3, 2022 at 17:15
16
Compass readings during turns are inaccurate and sometimes display turns when you are heading straight but accelerating. As such you need something that is referenced to the airframe turning itself. This is where the gyro comes in handy. Since it's referenced to the airframe and relatively unaffected over short periods of time it gives you your heading when your compass can not. You can also "time your turns" using the turn coordinator and a stop watch should your heading indicator fail. It should be noted that a timed turn will only work if the turn remains coordinated (no slip or skid) further more most turn coordinators are set up for 2 minute turns.
The errors are as follows
  1. If on a northerly heading and a turn is made toward east or west, the initial indication of the compass lags or indicates a turn in the opposite direction. The lag diminishes as the turn progresses toward the east or west where there is no turning error.
  2. If on a southerly heading and a turn is made toward east or west, the initial indication of the compass needle will indicate a greater amount of turn than is actually made. This lead also diminishes as the turn progresses toward east or west where there is no turn error.
  3. If a turn is made to a northerly heading from any direction, the compass indication when approaching northerly heading leads or is ahead of the turn. Therefore, the roll out of the turn is made before the desired heading is reached. If a turn is made to a southerly heading from any direction, the compass indication when approaching southerly headings lags behind the turn. Therefore, the roll out is made after the desired heading is passed. The amount of lead or lag is maximum on north / south headings and depends upon the angle of bank used and the latitude of the aircraft.
  4. When on an east or west heading, no error is apparent while entering a turn to north or south. However, an increase in airspeed will cause the compass to indicate a turn toward north. A decrease in airspeed will cause the compass to indicate a turn toward south.
The constant need to reset it is related to gyroscopic precession.
COST! What you need is a remote magnetic indicator. Some more advanced small planes have them. It's becoming less of the problem nowadays because even small airplanes get modern glass cockpits.
    $\begingroup$ That is called a flux gate. $\endgroup$
    – Mike Brass
    May 27, 2018 at 10:36
