I read the following on Flightradar24.com's 'How it works' page.
The percentage of aircraft equipped with ADS-B receivers is steadily increasing though, as they will become mandatory for most aircraft around the world by 2020. When mandatory, ADS-B will replace primary radar as the primary surveillance method used by ATC.
Sure, that sounds lovely, but it it seems to me that a large portion of aircraft do not actually use GPS, but instead rely on inertial navigation systems or similar. Of course, the ATC doesn't need millimeter precision, or even an accurate position within a kilometer, but whenever I check flightradar24, there is quite a large bunch of airplanes reporting their position with offsets up to a few kilometers - if I were to judge by the ADS-B data, I would report a major emergency every few minutes.
How will ADS-B actually reliably replace primary radar? Will GPS have become mandatory by 2020? Or is Flightradar24.com just being optimistic?
(Side note: I know that redundancy is very popular in the aviation world, but I don't think you can call something 'replaced' when primary radar is still used for a large portion of the flights)
Edit: some parts of some answers seem to be concentrating on update rate / transmission losses and errors. For clarification, I included a screenshot (which I could literally take the second I looked at fr24.com, indicating how often this happens).
At the time this picture was taken, the 36R runway was in use for landing ('yellow' aircraft top right just landed). The selected aircraft is however happily taxiing in a field (pattern matching 36R's adjacent taxiways). This is not caused by update rate or transmission losses (i.e., this can't be old information, the plane was never in that field). Transmission error also seems out of the question, since the entire track is a smooth line (errors sometimes do happen, but are not 'hidden' on fr24 - a large 'jump' in the track can be seen sometimes). So either the plane is reporting a 'wrong' position (how is this handled by ATC?) or fr24 somehow messes up the data (how is that possible?
