11
If a pilot has the opportunity to fly as an SIC in a private jet, what FAA requirements must they comply with in order to fly with passengers?
4 Answers 4
Don't know if the same rules still apply, but back in the 70s and 80s I used to fly legally as the second pilot on corporate jets with just a commercial license with IFR and multi-engine ratings. At the time I had no type ratings.
Theoretically you can fly a Boeing 747 on a Private Pilots Licence as long as you have the relevant type ratings. If you are flying passengers for profit you will then require at least a Commercial Pilots Licence.
Modern day training courses which prepare you to be the first officer or co-pilot as it were, tend to result in you holding a frozen ATPL, ie, you have done all the exams and you're now hour building in order to qualify for the licence. You will also likely have completed a Multi-Crew Co-operation course of some description, obtained your jet rating and hold any relevant Instrument Ratings. It probably depends on which provider you were choosing to apply for.
EDIT: Ah, my apologies, this post was in relation to European (EASA) guidelines (more specifically in the UK really).
  • $\begingroup$ If it were a privately operated 747 (which my question is about, not airline) then you don't even need a type rating do you? $\endgroup$
    – Lnafziger
    Mar 18, 2014 at 13:00
  • $\begingroup$ In the UK at least, you would need to be converted onto type. Else you could just step from a Cessna 152 into a Boeing 747 after getting a jet rating, and obviously if you do not know how to fly the aircraft, you're in a bit of trouble! :D $\endgroup$
    – Joe Harper
    Mar 18, 2014 at 13:03
    $\begingroup$ In the US, no type rating is required for the SIC, however it is for the PIC. $\endgroup$
    – Lnafziger
    Mar 18, 2014 at 14:22
In general, FAR Part 61, section 55a,b outlines specific requirements for those designated as Second-in-command of Aircraft requiring more than one pilot. Section b probably covers the specific training you're curious about. See also parts 121, 125, and 135 for more specific requirements.
    $\begingroup$ H brinky, welcome to Aviation StackOverflow! When answering questions, we prefer that you include the pertinent wording from the sources that you quote, (and even a link to it if you have it handy!) so that the question is answered in one place. Please click the edit link at the bottom of your answer to add more details if you want to improve it. For more info, see How to Answer, thanks! $\endgroup$
    – Lnafziger
    Feb 12, 2014 at 1:55
SIC: instrument rating, multi-engine (if more than one engine) Endorsements: high performance (200hp or greater)-high altitude - complex (retractable landing gear)
    $\begingroup$ Jets are not “complex” because they don’t have a controllable-pitch prop. $\endgroup$
    – StephenS
    Jun 9, 2022 at 22:59
  • $\begingroup$ @StephenS depends on jurisdiction. AFAIK under EASA anything with multiple engines and/or retracting gear is automatically complex. $\endgroup$
    – jwenting
    Jun 13, 2022 at 7:10
