10
Was travelling on a Airbus A320 (night flight) and during the safety briefing noticed that the fluorescent floor lighting strip referred to in the evacuation instructions was totally absent. Both sides of the aisle.
I could see the marks on the floor carpet where it must have been earlier tacked on. Was removed and went unreplaced for whatever reason.
Is it OK for an aircraft to fly without this item? Seemed pretty essential to me for a safe evacuation in the dark.
Edit: I did try & take a photo but unfortunately didn't come out so well.
    $\begingroup$ Did you get happen to get a picture? $\endgroup$ Jun 11 '15 at 20:04
  • $\begingroup$ @MikeFoxtrot: Yes! I did actually. I'll try & post. Not sure how nice it came out. $\endgroup$ Jun 12 '15 at 2:42
Those lights don't have to be mounted to the floor. They can also be seat mounted.
http://www.bruceind.com/index.php?option=com_k2&view=item&id=90:escape-path-lighting-systems&Itemid=189
http://www.astronics.com/_images/aircraft-safety/EPM%20033010.pdf
Seat mounted escape path lights
This is the AC that provides guidance on the requirements of the system. http://www.faa.gov/documentLibrary/media/Advisory_Circular/AC25.812-1A.pdf
The regulation is 14CFR 25.812
  • $\begingroup$ Interesting! Thanks. Maybe there were other lights that I did not see? Possible. Better safe then sorry though. I'll better report to the regulator & if there was a different system then no harm done. What do people think? $\endgroup$ Jun 13 '15 at 3:37
According to this document the answer would appear to be no if all lights were missing.
The 1/1 columns indicates the number installed and required for dispatch.
  • $\begingroup$ Thanks! I am going to email the regulator, just to see what they say. I will report back. $\endgroup$ Jun 12 '15 at 4:20
