How does the servo control spoiler actuation mechanism on the Airbus A340 work?
$\begingroup$ Don't limit yourself to searching on the A340. The A330 has a very similar wing and correspondingly similar systems. $\endgroup$– ThunderstrikeJun 8, 2015 at 9:16
2$\begingroup$ I'm a bit unclear on what you are looking for... the design of the actuation mechanism, spoiler flight computer or communication protocol between the two? $\endgroup$– ThunderstrikeJun 8, 2015 at 9:18
$\begingroup$ Design of the actuation mechanism $\endgroup$– Victor JulietJun 8, 2015 at 9:47
$\begingroup$ If I dont limit to A340, the answer might be marked as : too broad :D $\endgroup$– Victor JulietJun 8, 2015 at 9:48
$\begingroup$ @VictorJuliet, are you really asking about design of the actuation mechanism? Because you accepted an answer that does not even mention it. $\endgroup$– Jan HudecJul 29, 2016 at 6:20
1 Answer
Most aircraft utilize a weight on wheels switch. When the landing strut is compressed when ground contact is made, the weight on wheels switch is activated. The signal is distributed to various systems in the aircraft, including the spoiler system. The spoiler is activated as soon as the aircraft touches the ground to "scrub off" any lift and to make sure the aircraft doesn't become airborne as the jet engines spool down.
