I saw this image posted in another question. What airport is this?
This image was taken at London Gatwick. The bridge connects two portions of the North Terminal, right next to where the North Terminal is labeled on this map:
London Gatwick claims to be the first airport to have such a feature. As can be seen in the photo, it is the largest in the world, high enough for a 747 to pass underneath.
This is not the only airport to have such a feature, though. Denver International also has a bridge (picture) over the taxiway connecting the terminal building with Concourse A. This one is not as high as the bridge at Gatwick and can't clear anything larger than a 737.
$\begingroup$ Thanks, fooot! I got busy wandering around London area airports on Google maps, and forgot to come back to give you an upvote... $\endgroup$ – FreeMan Jun 5 '15 at 18:02
$\begingroup$ @FreeMan Interesting, I used Google and it identified Gatwick (and found the article I linked to). $\endgroup$ – fooot♦ Jun 5 '15 at 18:06
2$\begingroup$ You can see it in this Google Maps image -- they even took the photo just as a plane was going under the bridge. $\endgroup$ – Johnny Jun 5 '15 at 20:08
