Last week in Ecuador I was on a flight in a small plane (twin engine prop, full with pilot and 5 passengers). The passenger door opened in flight. I was in a position to grab the door and pull it back to the plane and hold it (against a very strong pull) until I could slam it partially shut and then hold it in place until we landed. It didn't seem like that big of a deal except when the door first flew open the plane seemed to drop about 50 feet. What caused the drop in altitude?
1$\begingroup$ When you say "dropped" do you mean that the nose came down and you lost some altitude or that the plane dropped 50ft like an elevator? Or did you even feel the drop at all? $\endgroup$ – Jay Carr Jun 3 '15 at 21:48
$\begingroup$ Is your question more about the door opening or why the airplane dropped 50 feet? You talked about the former a lot more than the dropped altitude. $\endgroup$ – Farhan♦ Jun 4 '15 at 14:15
2$\begingroup$ Did you notice that the altimeter indication dropped by 50ft, or was this really a change in altitude? Opening a door will affect the air pressure inside the cabin and thus also the altimeter readings of mechanical altimeters. $\endgroup$ – Peter Kämpf Jun 4 '15 at 14:54
In an unpressurized plane the door opening is less of an issue than in a pressurized plane but there are still some issues it presents. Its common for planes to have multiple latching mechanisms to try to prevent this from happening. In some cases they system is not perfect like this AD issued for the DA40 relating to the doors coming off in flight (due to improper closing it appears). Being able to run with out a door or open it in flight is even key for things like para-trooping and skydiving
Depending on the orientation of the door the biggest issue I would foresee is the door shearing off and damaging part of the empennage. This could a have serious if not potentially fatal impact on the plane.
Physically speaking the open door will create drag on the plane which may have been related to the decent you felt. It could also have been an inadvertent reaction by the pilot to the possibly loud noise.
On somewhat of a side note, most aircraft doors are oriented in such a way that the airflow will more or less push them shut (on small GA planes/non pressurized planes). Thus most doors open forwards like the ones on many pipers
Or vertically up so gravity will close them (note the baggage hatch). I would assume this is intentional but it may just be coincidence as that is also how car doors open. Along the opening lines, it is standard emergency procedure in small airplanes to unlatch the door before a forced landing incase the accident mangles the door locks.
For what its worth some planes are even flown with the hatch open most the time (pictured on the ground here but flown in the same config)
Here is a nice article written by a pilot about why it would be very hard (basically impossible) to do on a pressurized plane.
2$\begingroup$ You can also use the door of the PA-28 as a control surface to make right turns. - haha $\endgroup$ – reirab Jun 17 '15 at 18:15
$\begingroup$ Most car doors open that way for precisely the same reason most light-aircraft doors do (airflow pushing an unlatched door closed rather than open); there's a reason doors that open from the front and are hinged at the rear are called "suicide doors". Also, the DA40 AD link breaketh. $\endgroup$ – Vikki - formerly Sean Aug 10 '19 at 0:49
There can be many possible explanations to the Drop in altitude, and the most likely is being explained below:
- Increase in drag due to opening of the door, would result in decrease in velocity of the plane. This would reduce the lift and hence a loss in altitude would be observed. But, as soon as the altitude would have dropped, the pilot would have observed it and increased the throttle to counter that, and hence stabilizing the plane mid air.
