Fluid Structure Interaction (FSI) causes an aeroplane’s geometry to change and hence the forces on the different surfaces of an aeroplane become different than the forces expected according to initial calculation.
- Is this Fluid Structure Interaction considered while calculating forces (and hence the final design) of aircraft while finalizing the designs for aircraft?
- If it is considered, what are the available software packages which could be used to analyse this?
