I am not a pilot - just a student & play Ace Combat sometimes
So I turned off the flight turn assistant in the Ace Combat flight simulator/game & now I have to manually control bank & pitch to turn. I also like to use a little yaw for stabilizing myself.
If I am not wrong - both pitching & rolling are controlled by the control yoke in jets. So, when going for a right turn from level flight, what does the pilot do:
- Push the yoke a little right (attain 90+ degree rightward roll) and then pull the yoke towards him (to pitch up - i.e. actually execute the right turning arc). OR
- Pull the yoke in a diagonal way i.e. towards SouthEast (assuming pilot was initially heading north) or 4'o clock - and the flight's internal computers break down yoke movement movement into respective pitch and roll magnitudes.
Just curious.
