10
I haven't noticed any sort of plug door, so how do pilots board the B-2?
12
There is a hatch and a ladder in the bottom of the front fuselage, through which the pilots enter the bomber, as seen here:
Pilot hatch seen slightly to the left of the cockpit.
    $\begingroup$ Why have such a design? In the case of a belly landing, wouldn't the pilot be trapped inside? $\endgroup$ Commented May 30, 2015 at 8:19
    $\begingroup$ @MadhavSudarshan I would imagine it has something to do with the process of applying various stealth technologies and materials on the top of the fuselage, which something like a movable canopy, for example, could have compromised. Also, considering how the United States have superiority when it comes to advanced stealth technologies, I assume that an emergency landing on hostile territory would necessitate a self-destruction of the bomber. On friendly territory the plane could just be taken apart to get the pilots out; the bomber would be ruined from a stealth flight perspective anyhow. $\endgroup$
    – V-J
    Commented May 30, 2015 at 8:29
  • 9
    $\begingroup$ @MadhavSudarshan there are most probably zero-zero ejection seats and the upper escape panels above the cockpit might be able to jettison on their own. $\endgroup$ Commented May 30, 2015 at 9:17
    $\begingroup$ @MikeFoxtrot - there are indeed ejection seats, as the only loss of a B-2 did not involve the pilots - they ejected safely. In most ejection seat aircraft, ejection is preferable to a belly landing $\endgroup$
    – SSumner
    Commented May 30, 2015 at 21:47
    $\begingroup$ There are still ways to escape if the main exit is blocked. A B-1 has a similar arrangement, and the pilots got out after a belly landing. $\endgroup$
    – fooot
    Commented May 30, 2015 at 22:05
