Does anyone know how heavy are the combined landing gear on a Boeing 747?
It would be interesting if someone has also weight statistics per gear (nose gear and the four other main gear).
Sign up to join this communityDoes anyone know how heavy are the combined landing gear on a Boeing 747?
It seems I misspoke in my comment in which I gave the moments for 747-400BCF gear retraction. I didn't realize the component weights were further on in the document I referenced. The weights for the BCF are:
body gear 6447 lbs (2924 kg) each
wing gear 6508 lbs (2952 kg) each
nose gear 3157 lbs (1432 kg)
However, @Gurkan's comment is relevant in that you have to decide what all should be considered as part of the gear. So, I put up a PDF of the WEIGHT AND BALANCE CONTROL AND LOADING MANUAL for each of two 747 freighter variants. You can access them at terryliittschwager.com/wbmanuals.php. The most relevant sections are 1-86-041 and 051.
