I was wondering whether a microburst can occur at high altitudes?
1 Answer
Strong downbursts of air are possible at high levels also, for example in Cumulonimbus-clouds. However I wouldn't characterize them as microbursts, since the change of airflow direction is an equally dangerous and defining factor in microbursts.
(source: weather.gov.hk)
The head/tailwind parts don't exist at higher altitudes and you would experience the downdraft merely as turbulence.
