I've observed this on many flight trackers; the time taken to fly from A to B is not necessarily the same as the time taken to fly back from B to A. Why is this so and what external factors besides prevailing winds (headwind going one way, tailwind the other) create this difference in time taken?
Example: late May 2015, per American Airlines, PHL to MCO is about 15 minutes longer going south than going north, but times MIA to BDL are essentially identical in either direction. Prevailing winds would affect both routes similarly, but the difference in times northbound vs southbound isn't the same. Why not?
  • $\begingroup$ Related, if not duplicate: How Earth's rotation affect flight times? $\endgroup$
    – Farhan
    May 22, 2015 at 18:46
  • $\begingroup$ @MadhavSudarshan There are 2 things that haven't been mentioned that can affect flight times. Both are usually of small effect but they can on occasion be of more signfiicant effect. First, for example, a 747-200 at max takeoff weight will only be able to climb to FL290 to FL310 initially. If however, the load is light, you can go right up to, say, FL370 or higher. Also, your sequence in a series of flights bunched up at a popular departure tune along a popular route can make a real difference between the first aircraft and the last insofar as your choice of altitudes. $\endgroup$
    – Terry
    May 23, 2015 at 3:35
Sometimes, prevailing winds will account for the difference -- flights going west to east in the US will generally be scheduled for less time than flights going the opposite direction.
The other major factor that can play is in taxi times. If the delays waiting to get in to a gate matched the times waiting to depart at each airport, these delays would affect both legs equally, but that's not generally the case. Most of the time, at a congested airport like Atlanta, you can generally get into the gate fairly quickly, but the delays getting airborne can be far longer.
Thus, a flight scheduled from Podunk into ATL might be scheduled for 10 minutes taxi from the gate to departure at Podunk, the flight time, and another 10 or 15 minutes to taxi in, but in the other direction they might build in 30-45 minutes of taxi time departing ATL, plus the flight time, plus 5 minutes landing until blocking in at Podunk. Thus the leg into ATL is scheduled for flight time plus 25 minutes, while the leg from ATL is scheduled for flight time plus 35-50 minutes.
If it's winter time and your flight was going from BOS or PHL to MCO, another factor in addition to the potential for massive departure delays would be the need to build in time for deicing -- done before departure in PHL or BOS, but not so much leaving Orlando.
Of course, if you didn't need to deice "today," then you'd probably beat the scheduled time by a good bit. Likewise if the weather was clear and the airport had no delays. But the mega-hub airports run so close to capacity that any little hiccup in the weather or otherwise causes delays to start building, and then you're using all of your scheduled time, and sometimes more.
