I've heard that manufacturers (like Boeing and Airbus) constantly get data from their planes. So in the case of an emergency, ATC's or pilots can contact the manufacturers for assistance. How do manufacturers constantly get this data and how is it stored (cause considering the number of planes flying today, it must be a lot)?
  • $\begingroup$ Every purchase you and everyone else make at Walmart, Tesco, etc is stored centrally. There are a lot more purchases than planes. $\endgroup$
    – Hugh
    May 23, 2015 at 12:57
How do makers get data from aircraft in flight
The data is usually transmitted using something like ACARS which is a system used in aircraft to transmit data in flight using underlying radio and satellite communications systems.
The communications infrastructure is typically provided by large multinational companies who specialise in this job. See ARINC, SITA, Inmarsat and so on.
Engine-makers and Aircraft makers often offer pro-active maintenance and support services to airlines, operators and lessors which involve their aircraft transmitting such data to the makers.
For example, Airbus has AIRTHM
Airbus Real Time Health Monitoring (AiRTHM) is an advanced service through which A380 and A350 XWB operators can receive guidance on optimised maintenance and real-time troubleshooting actions. As part of this effort, a dedicated 24/7 team takes advantage of the uplink technology to further investigate and anticipate warnings/fault consequences.
The uplink technology allows real-time remote access to aircraft data parameters via the ACARS digital datalink system, enabling Airbus AiRTHM engineers to deliver maintenance and technical advice both in flight and on the ground.
Boeing have AHM
AHM sutomatically monitors, collects and transmits service levels using ACARS through the installed Aircraft Condition Monitoring System (ACMS)
Note that ACARS is a relatively low-volume data transmission system. Makers have explored other underlying communication systems as a way to transmit more data at lower cost.
How is this data stored
It is true that there is a lot of data but Boeing and Airbus are big businesses and are able to partner with major IT businesses.
For example IBM work with Airbus
“Today’s aircraft can generate up to a half terabyte of data per flight, an unprecedented volume and variety of data seen in few other industries,” said Timothy Wholey, IBM global leader for the aerospace and defense industry in its global business services unit.
Note - not all data has to be transmitted in flight. A lot of data is collected and stored in the plane and only transferred when the aircraft is on the ground.
Makers like Airbus and Boeing inevitably are already very heavy users of IT for aircraft design purposes. For example, Airbus use HP Supercomputing hardware
They are installed with some sensors which keep sending important data to the manufacturer. And, talking about their size, they are merely in just KBs, which is very small compared to storage the amount available even for all flights combined. Also, all information collection is automatic i.e. handled by computers so there is no problem in collecting information either.
Read: http://www.forbes.com/sites/johngoglia/2014/03/13/aircraft-engine-monitoring-how-it-works-and-how-it-could-help-malaysia-air-370-crash-investigtors/
Boeing has a system installed in many airplanes which monitors engine health. It is called Airplane Health Management. A good presentation can be seen here (more info here and here).
Airbus uses Airbus Real Time Health Monitoring (AiRTHM) which essentially does the same (more info here).
Please note that these systems are not installed on every single airplane but are getting popular more and more.
