While making a flight plan, depending upon the weight of the aircraft, I'm assuming pilots determine the takeoff distance. How do they do so (is there a formula to calculate the takeoff distance)?
$\begingroup$ Related: What would be the ground roll and total distance to clear a 50ft obstacle given these conditions? $\endgroup$– foootMay 20, 2015 at 16:31
$\begingroup$ See here for a practical example $\endgroup$– Peter KämpfMay 21, 2015 at 6:26
$\begingroup$ Are pilots to determine this? What about passengers and airline companies? $\endgroup$– David JonssonJun 26, 2021 at 0:17
Most airplanes have a POH (Pilot Operating Handbook) with a table on aircraft distances. Here I have included one for the C172.
Takeoff data is calculated using performance charts and/or software. Data input into the algorithm include:
- runway condition
- runway slope,
- wind (headwind or tailwind component),
- takeoff weight,
- aircraft configuration (flaps, slats, etc)
- density altitude
The air carrier I flew for had a performance chart for every runway we operated from (all scheduled and alternate destinations) that we could reference for the max allowable takeoff weight for that runway, flap configuration, wind condition and temperature. We didn't actually calculate the takeoff roll distance, but rather that we were below the max weight that could accelerate to V1 and stop within the distance provided by the runway in the current wind, temperature and aircraft configuration.
The previous answers are indeed correct; I will take it one step farther up the stack, though, and make a point that may have been unclear and addresses an assumption.
The pilot doesn't calculate take-off distances; they are looked up.
As mentioned, external data sources are used. The manufacturer of the aircraft, based upon their own math and the results of real-world-testing, is the authoritative source. Once it's in the operating handbook, you can be confident of those numbers (and, in fact, shouldn't second-guess them without a bloody good reason). As was also mentioned, some operators do their own testing; these results then go into the operating handbook, and the pilot is then expected to be able to count on those numbers as long as they follow the same procedure.
One of the most important aspects of flight is consistency; given the same external conditions, all aircraft of a particular model and particular takeoff weight should perform very similarly. This is more than just minimums. In the case of a broken instrument, whatever is being measured by the broken instrument can usually be inferred from other instruments. An example would be airspeed; if your airspeed indicator is broken, but you know your engine RPM and know that you're not climbing or descending, then you should always be about the same airspeed given that engine speed. A Cessna 172S would always be very near 120kts at 2400rpm at 2200 pounds weight. This consistency is what allows those numbers to be recovered and depended upon. (pulling numbers from head; the point is that you should be able to go into ANY Cessna 172S and expect the same performance as long as the plane has been properly maintained).
This is also true of many other critical aspects of an aircraft's performance. Climb rates, fuel consumption, rate of change-of-direction in a turn... these numbers all have to be accurate, as they can mean the difference between making the runway and becoming a news story.
Besides using tables, aircraft manufacturers also provide a takeoff chart, like this:
The chart goes from left to right:
- Enter the air temperature, then go up until you met your pressure altitude. Then proceed horizontally to the right.
- Follow the contour of the lines, until you meet your weight on the x-axis. Proceed horizontally to the right.
- Follow the contour of the lines, until you meet your headwind (or tailwind) component in the x-axis. There, leave the contour and go horizontally to the right.
- The y-axis gives your takeoff roll distance. If there is an obstacle 50 feet at the end of the runway, follow the lines to get your "takeoff roll + clear obstacle" ground distance.
Some manufacturers provide tables. Some provide charts. Some do both.
The way we teach at our school is that, for example, if you are doing a normal takeoff and your POH only has short field effort, take the Vr and the Vlof, and find the difference. For a C172sp that is roughly 9kts difference. So now take your normal takeoff speed, and add that difference for your Vlof normal. You'll find that it's almost a 10% increase in speed. As a rule of thumb, a 10% increase in speed will equal about a 21% increase in distance.
