If all winglets serve the same purpose (to reduce vortex drag), why do different aircraft have different winglets? This question is not trying to get a comparison of the development of winglets/wingtips, with other aircraft components, as the question of @Manu H is.
1 Answer
Winglet design is driven more by marketing than by engineering, so every aircraft brand tries to cultivate their own, supposedly better, shape.
A study by Nita and Scholz (PDF!), Chapter 6 gives a good overview over recent winglet studies. A raked tip performs better, and if winglets could point downwards, they also could do better. As they are, they give only 28% to 38% drag reduction of an equivalent span increase.
Raked wingtip of the Boeing 777-300
$\begingroup$ Thanks! This is great. I take it the newer split winglets don't really include the benefits of a downward-pointing winglet, since they primarily point upwards? $\endgroup$– egidMay 17, 2015 at 17:23
1$\begingroup$ @egid: A downward pointing winglet is only slightly better, and with the limited size cannot effect drag much. Theoretically, a variable-geometry winglet which can be folded up for landing would capture the benefit, but would work best when stopped halfway in the transition from pointing upward to pointing downward ;-) $\endgroup$ May 17, 2015 at 19:33
$\begingroup$ @PeterKämpf Do you have link where you explain how raked wingtips works?Is raked wingtips better than simple horizontal extension? $\endgroup$ Sep 1, 2020 at 8:27
