22
Is there generally a minimum altitude for ejecting in order for the sequence to function reliably (all the way to opening the chute, and slowing down to a survivable descent rate)? I've seen ejector seats test being done on the ground, don't know if there were actually test pilots in those seats though.
Low-Leve F-16 Ejection
I assume all bets are off if you're not wings level (obviously a low-level inverted ejection has a 0% chance of success).
    $\begingroup$ Not an answer, but some info: en.wikipedia.org/wiki/Ejection_seat#Zero-zero_ejection_seat $\endgroup$
    – yankeekilo
    Jan 30, 2014 at 15:12
    $\begingroup$ In 1971 an Air Force Pitol was flying so very low over 1st Marine Division some seven miles north of Danang Air Force Base. The pilot's control stick in his Fighter Jet had malfunctioned, and he was doing everything possible to keep crashing into Marine barracks. I heard this "very load noise" and ran out of a building just as the jet went overhead. The letters on the plane could be easily read. Suddenly, the pilot observed were the high Division ridges sloped downward to sea-level like a "V", and he was able to point the nose of his plane into that "V" and ejected. The plane crashed and explo $\endgroup$
    – Bruce Reed
    Feb 27, 2017 at 18:15
    $\begingroup$ Let's hope for humanity's sake that there was indeed no "Test" Pilot...lol $\endgroup$
    – Prodnegel
    Feb 27, 2017 at 18:37
    $\begingroup$ @Prodnegel: Actually, for at least one zero-zero seat, there was! $\endgroup$
    – Vikki
    Nov 1, 2018 at 0:23
5 Answers 5
23
It depends on the ejection seat.
Modern zero-zero ejection seats are designed to be usable at zero speed, zero altitude.
Older ejection seats had different minimums which varied from model to model.
On a side note, the early F-104 ejection seats required quite a bit of altitude to deploy properly, since the pilot exited through the bottom of the aircraft. This was done because there was some concern that the pilot would hit the F-104's T-tail with a standard ejection seat.
EDIT
It appears that it may actually be possible to eject from an inverted aircraft. According to Wikipedia (bold added for emphasis):
The minimal ejection altitude for ACES II seat in inverted flight is about 140 feet (43 m) above ground level at 150 KIAS. While the Russian counterpart - K-36DM has the minimal ejection altitude from inverted flight of 100 feet (30 m) AGL. When an aircraft is equipped with the Zvezda K-36DM ejection seat and the pilot is wearing the КО-15 protective gear, he is able to eject at airspeeds from 0 to 1,400 kilometres per hour (870 mph) and altitudes of 0 to 25 km (16 mi or about 82,000 ft). The K-36DM ejection seat features drag chutes and a small shield that rises between the pilot's legs to deflect air around the pilot.
    $\begingroup$ I read somewhere that some ejection seats require a minimum speed as well, do you know why that is? $\endgroup$
    – falstro
    Jan 30, 2014 at 17:26
    $\begingroup$ @roe: not sure, good question. Maybe another answerer can help on that. $\endgroup$ Jan 30, 2014 at 17:34
    $\begingroup$ @roe: The minimum speed is for the parachute, not for the seat itself. I only have this second-hand, though, from a pilot quoting his instructor in an article about something else. $\endgroup$ Jan 30, 2014 at 19:47
  • 11
    $\begingroup$ Modern ejection seats like the ones capable of inverted flight will "right" the pilot after exiting the aircraft, then fire rockets to gain enough altitude. That's how you can eject 100 feet above the ground upside-down and survive $\endgroup$
    – SSumner
    Jan 31, 2014 at 21:57
13
Pilots have successfully ejected at negative altitudes in a handful of instances, after being forced to ditch in water.
Documented evidence exists that pilots of the US and Indian Navies have performed this feat.
Also: I once read, but cannot now locate, the citation awarded a pilot of the USAF for the world record lowest altitude successful (i.e. the pilot survived) emergency ejection from a stricken aircraft over land: sixteen feet below ground level. Apparently the young pilot was practicing with his T-33 single-engine trainer when the engine flamed out and could not be restarted. The pilot observed the flat desert below, crossed by several paved roads and highways. One road seemed to be completely clear of traffic, so he opted for a gear-down dead-stick landing on it, hoping to minimize damage to the aircraft. He discovered only after touchdown that the paved strip was not a road at all but a flash flood drainage ditch, wide enough for the fuselage but not the wings. The aircraft was seriously damaged and set on fire. The damage prevented the canopy from opening, so the pilot used the ejection seat to escape burning to death. He survived with minor burns, some compression damage to his spine, and two broken ankles.
    $\begingroup$ The interpretaion of "negative altitudes" into "underwater" is a bit mistakable. You could also eject in Death Valley and be below MSL... $\endgroup$
    – yankeekilo
    Jan 30, 2014 at 17:36
    $\begingroup$ Actually I was interpreting "underwater" as "negative altitude", not the other way round. $\endgroup$ Jan 30, 2014 at 17:51
    $\begingroup$ Now that you mention it, I think Death Valley would be a perfect place to set up an ejection seat research and test facility -- just for the "negative altitude" bragging rights. $\endgroup$ Jan 30, 2014 at 17:53
    $\begingroup$ Yeah, I read the Wikipedia entry and kind of reverse-engineered your statement. So the article is kind of ambiguous. Since the incidents are Navy, I´d guess they ejected from a sinking jet. $\endgroup$
    – yankeekilo
    Jan 30, 2014 at 18:25
    $\begingroup$ Shouldn't "negative altitude", to have a useful meaning, be relative to ground, not sea level? $\endgroup$ Jun 20, 2018 at 9:30
The Martin Baker MkGRU7 and EA7 on both the A6 Intruder and on the EA6B Prowler aircraft have "zero-zero" capability, which means that the seats could be fired at zero AGL and zero airspeed.
Quite a few years back, about 28 to be exact I worked on Mirage III service for the RAAF and one of my jobs was to fit the ejection seats after major airframe servicing.
Originally they were fitted with Martin Baker OM6 and these seats were zero-90 classification. They were powered by cartridges, basically a big multi stage canon that shot you out of the plane.
This means they were able to be used at zero altitude and 90 knots forward speed, the speed was purely to have enough air flow to open the chute fully but mostly to help with the removal of the canopy by blowing it backwards. The canopy jettison would unlock the canopy and lift the front into the airstream, the forward motion would do the rest.
Later we made a modification to the seats to make them into zero/zero capability and this included fitting a rocket pack under the seat that would launch the seat to a safe height enough for the parachute to open normally. In both cases the seats were capable of going through the canopy but normally the canopy would eject first except in the zero zero situation where the seat would go through the canopy.
It all depends upon the seat type, altitude, speed, attitude and orientation of the aircraft during the ejection process. Ejection seats just provide a velocity vector in order to give the pilot enough time to clear the crippled aircraft and deploy the recovery parachute, as this USAF training film shows.
This results in an envelope of airspeed, altitude, and attitude in which the seat can be activated allowing for a safe recovery.
For a so called 'Zero-Zero' ejection seat, it allows for a safe ejection from an aircraft on the ground in level flight attitude. It does NOT guarantee safe ejection from an aircraft in unusual or inverted attitudes at low altitudes or airspeeds.
In the Boeing ACES II ejection seat a basic guide to seat characteristics is given here.
I can't comment on the capabilities of the Russian seats. However the Russians do have a tendancy to be excessivly boastful and colorful with a gullible western press, such as the 1989 crash of a MiG-29 at the Paris Airshow, where the press ran with a story about the K36 seats being able to safely eject at low altitudes and extreme attitudes. The reality was the seat in this incident was activated outside of its safety envelope; the pilot was just lucky he wasn't killed.
