13
When I take commercial flights, or you see turns in the vapour trails, they turn very sharply. What's the reason for this - wouldn't it be more efficient to turn gradually?
    $\begingroup$ Are you asking why airplanes make "sharp" turns, or are you asking why they're making turns at all (going in a straight line from A to B is, after all, a lot more efficient)? $\endgroup$
    – falstro
    Jan 29, 2014 at 8:24
    $\begingroup$ Lnafziger's answer below is correct in that a higher speeds it requires more bank to maintain a standard rate. That said, 30 degrees of bank is more typical of how pilots fly with passengers. 30 degrees of bank is nothing really to a pilot. Even at the most basic Private Pilot (US) standard in a small airplane the minimum required is to demonstrate 45 degrees of bank and up to 60 is allowed for the aircraft. Aerobatic airplanes can do 70-80 degrees of bank while maintaining level flight, they can even flip over 180 degrees and fly upside down. $\endgroup$
    – p1l0t
    Jan 29, 2014 at 14:26
    $\begingroup$ FWIW, the last 747 carrier I worked for had a statement in their ops specs that banks should be limited to 20 degrees when within 4000 feet of the ground for passenger comfort unless there was an overriding need to bank steeper. $\endgroup$
    – Terry
    Mar 31, 2014 at 3:28
  • $\begingroup$ This landing from the South includes reversing course by 180° at about 5 km from the threshold with two 90° left turns. Does that match your observations? $\endgroup$
    – mins
    May 20, 2016 at 5:39
22
Airplanes are expected by air traffic control to turn at a "standard rate of turn" which is 3 degrees per second. This will provide a 90 degree turn in 30 seconds. A standard rate is used so that controllers can anticipate how long it takes for an airplane to turn to a heading and they can line them up easier. It also makes the turn happen in a smaller amount of airspace so that two airplanes can be flying in the same general vicinity without getting too close.
Unfortunately, at the speeds that jet airplanes travel this would mean a very high angle of bank. A standard rate turn at 200 KT TAS is about 30 degrees of bank and jets can go much faster than this, which would require even higher bank angles. They actually limit it to 25 degrees of bank when using a flight director, mainly for passenger comfort.
It can be impressive when looking out the window and seeing the ground, but don't worry, the airplane is more than designed for it!
This is used mainly at lower altitudes where there are lots of airplanes. Once they are up high and airplanes are further apart (and the turns are also usually smaller) they can bank even less (by using a "half-bank" mode) which adds to passenger comfort.
    $\begingroup$ 30 seconds for a quarter turn at a speed of 878km/h means a turning radius of 4.6km $\endgroup$ Jan 29, 2014 at 10:02
    $\begingroup$ I always thought large aircraft use half rate turns (4 minute turns instead of 2 minute ones), but I can't find authoritative reference and can't find definition of "large" for this purpose. $\endgroup$
    Feb 9, 2014 at 21:04
    $\begingroup$ There is another question for explaining this. $\endgroup$
    Feb 9, 2014 at 21:16
  • $\begingroup$ @JanHudec The FAA definition of "large" is any aircraft weighing more than 12,500 lbs. (14 CFR 1.1). As far as the other question, he asked it after seeing the answer to this one (and this answer kind of answers that too, by explaining how fast they actually turn. :) ) $\endgroup$
    – Lnafziger
    Feb 9, 2014 at 21:55
Airliners actually turn relatively slowly, but are often so far away (when viewed from the ground) that they appear to be turning sharply. An airliner cruising at 35,000 feet is actually over 7 miles away, which makes scale hard to comprehend.
From the air, riding in an airliner, you may be confusing rate of turn with roll rate or angle of bank. An airliner will roll relatively smoothly into a bank angle of up to 30° (which can seem steep), and a rate of turn (change in compass heading) of between 3° and 1.5° per second. You often don't feel the roll, but will observe the bank by looking out the window.
The reason for the 1.5-3° turn rate is so that Air Traffic Control can have some way to predict where an aircraft will be in x seconds. Rate of turn is standardized, making that possible.
    $\begingroup$ "An airliner cruising at 35,000 feet is actually over 7 miles away, which makes scale hard to comprehend." And that's if it's almost directly overhead. If they appear to be near the horizon and they're flying at that altitude, they could be 100 mi or even 200 mi away on a clear day, especially if your horizon is clear of obstacles. $\endgroup$
    – reirab
    Mar 31, 2014 at 20:32
Most aircraft tend to make standard rate two-minute turns, as in it would take them two minutes to turn 360 degrees (3 degrees per second). At higher altitudes and higher speeds (or heavier aircraft) they might do half-rate (four minute) turns, which are 1.5 degrees per second.
So at a higher speed (which high-flying planes are likely to be at), to turn a the same rate, they must bank more sharply. That's why at higher speeds the halve the rate, so they can reduce the required bank angle.
More likely though, it's just your perspective. From your position on the ground it looks like they're turning sharply but in reality it took them several miles to make the turn. From your position in the plane, it's difficult to comprehend how fast you're going.
Finally, at higher airspeed speed sharper bank angles are required to keep the plane coordinated during a standard rate turn. This means that when you turn, you feel like you're being pressed down into your seat instead of sideways out of it (like when you take a turn fast in a car).
    $\begingroup$ Hmm, your last paragraph reads like you are saying that an airplane can't be coordinated at a small angle of bank....? $\endgroup$
    – Lnafziger
    Jan 29, 2014 at 3:06
