13
I have flight logs for a WW II B-24 navigator who flew with a combat crew in China Burma India. There is a column for number of landings. The entries range from 1 to 5 or 6, mostly 1 or 2. The time can be as long as 8:00 to 10:00 or more. Why is the number of landings recorded? Is that still done today?
    $\begingroup$ When you say flight logs, do you mean logs for the navigator or for the aircraft? $\endgroup$ Commented Apr 6, 2015 at 19:33
6 Answers 6
18
Yes, it's still done today, at least in military aviation.
It's to ensure that the undercarriage does not excede the number of landings it has to endure before being checked/overhauled/replaced. Landing an aircraft can typically be the most stressful regime of flight in terms of loading of certain bits of the aircraft, so it is pertinent to log how many times it happens per flight.
    $\begingroup$ how many times it happens per flight you mean that a touch-and-go would be/is counted as "landing"? $\endgroup$
    – Federico
    Commented Apr 6, 2015 at 13:05
    $\begingroup$ That's correct. $\endgroup$
    – Liam Baron
    Commented Apr 6, 2015 at 13:10
    $\begingroup$ @LiamBaron is this aircraft logs, or pilot logs? As a GA pilot I've always logged landings for my own FAA records, but never for an airframe or in an aircraft flight log. $\endgroup$
    – egid
    Commented Apr 6, 2015 at 16:45
  • $\begingroup$ My answer is for aircraft logs. In military this record is always kept as part of the aircraft documentation. $\endgroup$
    – Liam Baron
    Commented Apr 6, 2015 at 18:54
    $\begingroup$ though the question seems related to the logs of a crew member, not of the aircraft. $\endgroup$
    – Federico
    Commented Apr 6, 2015 at 19:02
14
I'm not sure if this is specifically a military question or a general question. In general aviation (FAA) you are required to do a certain number of landings every 3 months to stay current. So landings are logged for this reason.
The specific regulation is 14 CFR 61.57 (a) (1), which says (emphasis added):
[…] no person may act as a pilot in command of an aircraft carrying passengers or of an aircraft certificated for more than one pilot flight crewmember unless that person has made at least three takeoffs and three landings within the preceding 90 days […]
I am not yet rated for IFR, so I'm not sure on the specifics about IFR currency mentioned in this regulation. The currency for VFR related flight differs from day and night; however, 3 night landings in 90 days will count to keep you current, while 3 day landings will only keep you current for daytime VFR.
A note on military training:
I was able to find this book/article that alludes to the training of navigators during the second world war; on P.585:
Before 1933 instruction in navigation was given only as part of pilot training.
If the individual in question had a military career and joined before '33 he may have been a pilot first and simply continued with the same log book. Why the landings were logged may just be force of habit. Either way its an interesting read on how difficult it was to be a navigator at the time and exactly what it took to become one.
  • $\begingroup$ Pilot logbooks also have a column for number of landings as well. (At least they did when I was flying) $\endgroup$
    – Tim
    Commented Apr 6, 2015 at 16:28
  • $\begingroup$ They still do, at least the Jeppesen one I use has it, I believe it is there for this very reason. $\endgroup$
    – Dave
    Commented Apr 6, 2015 at 16:49
  • $\begingroup$ @dave if i read correctly it is logbook for navigator, not the pilot. Is there any info regarding navigator logbook as well? $\endgroup$
    – vasin1987
    Commented Apr 6, 2015 at 16:54
  • $\begingroup$ I can not find anything specific but the navigator certification/position is not really issued or filled anymore and thus there is not really a need for navigator specific log books. That being said there may have been specific log books for them back in the day and the navigator certification may have also had a landing requirement but I do not know so I cant comment on it as it is not really addressed in the FAR currently. $\endgroup$
    – Dave
    Commented Apr 6, 2015 at 17:00
Landing is not the easiest thing on an airframe! It imparts a lot of stress, and everything we build is designed and evaluated by some statistician to endure a certain number of uses + or - some standard deviation that he/she defines. Even the keys on your keyboard are meant to endure a certain number of presses.
Additionally, if you CAN collect data that you suspect may be useful later, why not? You never know when you may want to use it for something you didn't intend to.
Not sure about the navigator though.
  • $\begingroup$ It would also track take-offs, of course (+/- 1) which I guess are also stressful. $\endgroup$
    – Dan
    Commented Sep 27, 2020 at 1:10
For aircrew, yes there are certain requirements including no. of LDGs to be conducted within xx timeframe (typically 3 months / 90 days) in order to maintain currency. This information is recorded in the Pilot Logbook. Mine didn't have a special column (NZCAA type) so you would just write what was pertinent in the narrative, using as many lines as required.
For part 91 & 135 GA aircraft I'm not aware of any that require records to be kept of LDGs. In the airline industry cycles are recorded - this pertains more to the number of pressurisations, but on some a/c I believe LDGs are recorded also.
On the McDonnel-Douglas A-4K Skyhawks (Scooter in USN) that I maintained in the '80s we recorded LDG cycles, as well as g-force excursions. This pertains to airframe fatigue and cycle life. During peacetime fighters often last many more years (decades?) than would be reasonable for designers to estimate under true combat conditions, hence airframes can actually wear out, by reaching design time/life limits. This is especially applicable to naval aircraft operating from carriers. Even when the RNZAF operated A-4s, land based only, the initial "thump" of LDG usually produced more g, albeit momentarily, than a maximum performance ACM manoeuvre. They could have been landed "softly"; main RWY at their home field was ~2500m, but what the heck these were carrier aeroplanes and the pilots knew it. So they took delight in extending that 500mm or so of impact absorbing oil-damped undercarriage travel (top MX bikes have only 300mm) to its full effect. That was a good reason to log landings. JSB
I suspect it has to do with the fact that pilots want/need records of that for certification purposes and Pilot In Command can change in the middle of a flight. Seems silly for a navigator though.
  • $\begingroup$ Landing is one of the more important times where navigation is needed. $\endgroup$
    – fooot
    Commented Apr 6, 2015 at 19:04
  • $\begingroup$ @fooot Finding the airport and landing there are entirely different skills. $\endgroup$
    – StephenS
    Commented Sep 26, 2020 at 17:27
All the answers to date seem to have missed the most obvious part: landing the plane is by far the most difficult (and arguably the most important) part of flying, at least VFR. So the reason a certain number of landings within a given period is required to maintain currency is simply to ensure that the pilot remains practiced in doing them. And the reason they're logged (and logbooks have a column for it) is so that you can show currency if you ever need to.
While landings might need to be recorded for some military or commercial airframes, it's simply not true for most aircraft.
