I imagine plane having only four flaps in the back (one on top, bottom, left and right), similar to ailerons but longer and narrower. They can open from the fuselage to correct the plane's yaw or angle. I predict that this would increase efficiency of the plane since there's no drag from the horizontal and vertical stabilizers.
Can this design work?
  • $\begingroup$ Re "They can open from the fuselage" -- are you imagine a surface hinged on the front edge, that lies flush against the fuselage when not in use? Like the speed brakes on a F-86 or F-15? If so, I think the answers posted so far have missed this point. Or do you mean surfaces just like the all-moving horizontal stabilizer on many current jet fighters, but that retract whenever not actively being deflected? The question needs more clarity. – $\endgroup$ May 8, 2021 at 17:01
12
Your question is partly covered here regarding why the vertical stabilizer is important. The empennage (tail surfaces) of conventional planes provides both passive and active stability. Like the feathers on an arrow (which is where the word empennage comes from), they help the airplane to remain pointed in the direction of flight as well as providing active control surfaces. The cost of providing stability is added weight and drag, but if the surfaces are removed, the stability aspect will need to be provided manually, or alternately. This is how unconventional aircraft like the B-2 flying wing, or even modern fighter aircraft, are able to fly.
So, yes, we can fly airplanes without conventional tail surfaces. Some designers like Burt Rutan have created unconventional designs for general aviation. However, design changes will also have drawbacks. At the very least these designs behave differently than conventional planes, which requires special attention. The strange appearance is also reason for some pilots to distrust them.
If the plane is going to be unstable without computer control, that introduces safety problems. In military aircraft the pilots can eject when issues arise. But unlike modern commercial planes, the pilots cannot simply take over control if the computers fail.
There is also an aerodynamic issue with what you propose. Conventional control surfaces deflect the entire surface, so air continues to flow past both sides. However, if you only deflect one side of the surface, air is only flowing past the outer face. This acts like a spoiler and creates extra drag. Though this drag will be the force controlling the plane, it is not as efficient as moving a control surface. As Peter Kämpf pointed out, it is much more feasible to increase the effectiveness of the existing surfaces than to eliminate them.
Modern airliners represent a compromise between efficiency and safety based on currently available technology. Although alternate designs have been proposed, these configurations create their own unique problems.
  • $\begingroup$ Great answer! Though I don't understand why a moving surface is more efficient. Doesn't the rudder create just as much air resistance as the opening flaps I proposed? $\endgroup$
    – Ewen W.
    Apr 6, 2015 at 15:50
  • $\begingroup$ @EwenW. you need some surface there to provide stability, and replacing that with a computer presents safety issues. I have edited my question to hopefully explain better. $\endgroup$
    – fooot
    Apr 6, 2015 at 15:55
  • $\begingroup$ Just a side question if you don't mind answering.. Approximately what percent of fuel consumption could the plane cut down assuming that it has no stabilizers and flies perfectly balanced (though highly unlikely). $\endgroup$
    – Ewen W.
    Apr 6, 2015 at 21:55
  • $\begingroup$ @EwenW. I couldn't find a quick answer right now, maybe the drag of different airplane sections is worth a separate question. $\endgroup$
    – fooot
    Apr 6, 2015 at 22:25
    $\begingroup$ @EwenW. Approximately 100%. Because it will crash and never fly again, therefore using no additional fuel. :) $\endgroup$
    – reirab
    Jun 12, 2015 at 19:22
First let me clarify: You propose four moving surfaces which extend as needed (I guess that is what you mean by "open from the fuselage") from the fuselage?
Yes, theoretically it can work, but the flaps need to be as big as the surfaces they are intended to replace and need to be out in the airstream all the time. That would look remarkably like what we currently have, so any hopes of significantly reducing drag are unfounded.
Now there is a scenario where drag savings on the flaps are possible. Tail surfaces don't work at their maximum or even optimum lift (optimum meaning at their best lift to drag ratio) most of the time, so the degree of extension could be smaller, and less surface area is exposed. But where do you stow all the remaining part of the flap? Now you need to make the fuselage that much bigger, so you lose in fuselage drag what you gain in tail area drag. Add to this the weight of the kinematics for moving the flaps, and the conventional design looks ever more attractive.
As @fooot has pointed out, this scenario needs computer control and added layers of safety like secondary means of flap movement if the primary actuators fail.
If no asymmetric thrust scenario is possible, earlier designs have already proposed to do away with the whole vertical tail and replace it with a small, computer-controlled fin at the nose, yielding significant weight and drag savings.
Aircraft designers have constantly tried to reduce tail surfaces to the minimum they can get away with. Please look at the picture of the An-70 below closely: The horizontal tail has slats which open forward and up, so the tail surface can produce more downforce when flaps are extended. This is a trick to reduce the tail area, which doesn't need to produce much downforce during most of the flight, at the expense of more drag with flaps extended and more moving parts.
An-70 at Paris Airshow in 2000
An-70 at Paris Airshow in 2000 (own work)
  • $\begingroup$ Thanks for the answer, but why do the flaps have to be out in the airstream all the time? Surely the plane can fly quite some distance without the need for adjusting the yaw or elevation, or am I missing something? $\endgroup$
    – Ewen W.
    Apr 6, 2015 at 15:44
    $\begingroup$ @EwenW.: If you want natural stability (no electronics, no redundancy, works all by itself), you need something at the back to produce an opposing force as soon as the aircraft deviates from the desired state. This works automatically, but only if the stabilizing surface is out all the time. With computer controlled stability, you still need something smaller out there to be able to react immediately. Since the aircraft is unstable without those tail surfaces, the smaller flaps need to move all the time, and need to do this much faster than the period of the fastest eigenfrequency of motion. $\endgroup$ Apr 6, 2015 at 18:52
  • $\begingroup$ "at the expense of more drag with flaps extended" Most of the times when you have flaps extended (landing, rejected takeoff), more drag is a good thing. $\endgroup$
    – Vikki
    Sep 11, 2020 at 0:30
  • $\begingroup$ I think that photo is own work, right? If so can you add that please? Also nice photo! PS awesome remark on the early computer-controlled fwd fin! $\endgroup$
    – user14897
    May 8, 2021 at 15:40
  • $\begingroup$ @ymb1 You guessed right. $\endgroup$ May 8, 2021 at 18:28
Yes that is possible, but impractical.
  • Such a design would use asymmetrical drag to compensate for moments about the centre of gravity. Conventional tailplanes use asymmetrical lift, which has a much lower drag-to-force ratio.
  • The horizontal tailplane provides an additional spot for lift, so that there is a practical range of CoG locations. The bottom or top flap of the replacement design would have to be permanently deflected, again with higher drag.
It is possible to design such a system as a passive system though, like the designers of Kamov seem to have done.
