In general what can i expect of small, 4-seat, light airplane? I am specifically interested in the Pipistrel Panthera, though general responses would be appreciated.
  1. What is usual range of that kind of plane?
  2. What is the worst weather under which it can fly?
  3. How expensive is to fly internationally with that kind of plane?
  4. What is the procedure and usual cost for example if I fly from Rome to Prague, what border control checks can I expect? How and what kind of taxes related to that particular flight would I pay?
  5. If a plane is declared to have range of 1900 km, what is practical range in practice?
  6. If regular service for an airplane is declared to be after 7000 km of flight or X hours of flight, what has to be done usually in those services? Changing of oil, changing of filters?? How expensive usually is that?
  7. Anything else you think is important to know about possessing and airplane of that type?
    $\begingroup$ This is a lot of questions asked in one. Please try to narrow your question to a single core question, perhaps on range? $\endgroup$ – raptortech97 Mar 30 '15 at 13:50
    $\begingroup$ Hello mariotanenbaum, welcome to Aviation.SE. These are too many questions at once to be answered. Please try to cut it up to multiple, single-issue questions. $\endgroup$ – DeltaLima Mar 30 '15 at 13:59
    $\begingroup$ And this question may help you as well. $\endgroup$ – DeltaLima Mar 30 '15 at 14:00
  • $\begingroup$ I know that it's many questions, but imagine you are somebody who doesn't have any info and you don't want to spend 5 hours searching for each answer. Also, i didn't ask for great details, just in general. Doesn't need to be very precise and 100% correct. $\endgroup$ – mariotanenbaum Mar 30 '15 at 14:02
    $\begingroup$ @mariotanenbaum Without splitting the question up, the answers must be kept short and specific, which is less useful to others looking for information. The title of "what are capabilities" is also very vague and unhelpful for anyone else looking for the information. If you limit the questions to just the aircraft you mentioned, it would be more useful. $\endgroup$ – fooot Mar 30 '15 at 14:47
You have a few questions and the answers to them vary greatly based on the plane in question. It's often said you should chose the plane for your "mission" which means you should think about what you would like to do with the plane and then chose the plane that best fits that "mission". But anyway let's address some of the questions at hand.
What is usual range of that kind of planes
This depends on the plane. Small planes can get anywhere from 500 nautical miles to upwards of 1500 nautical miles depending on fuel load and optional tank configuration. But the middle of that range seems to be the average. I have found that range is more dependent on how long you can sit in the plane not now much gas you can carry. Remember there is no bathroom on these little planes and some are not the most comfortable things in the world.
What is the worst weather under which it's ok to fly that kind of airplane?
Although this is changing most small aircraft are not certified to fly in ice. Some can be modified to do so and some come with the option when you buy it. That being said I don't know if I would fly a small plane in ice but IMC is possible and done all the time. Remember also that fancy equipment does not always mean you are safer, you are still flying a tiny plane in bad weather.
Rain is possible but keep in mind rain on the ground could mean ice in the air depending on the temperature. Some small airplanes will be able to climb above this but that depends on plane.
Wind is limited by the airports you are flying to and from. If the wind is blowing down the runway you are good to go but every small plane has a maximum demonstrated crosswind component that will limit your ability to fly in high winds at some single runway airports where a crosswind landing is the only option.
How expensive is to fly internationally with that kind of plane.
Again this changes from plane to plane and country to country. Small pipers can be flown for (from what I have read) under 10K(USD) a year and less if you don't fly very often. With older planes you will pay more in maintenance and less in up front cost while with a new plane you will pay more to buy it and less to maintain it as its fresh. You will also have to factor in gas and insurance. Insurance depends on YOU and your flying time so its hard to say what that will fall in. Gas here in the US (100LL) is around 4.56-6.00 where I am so figure in that based on fuel burn etc.
What is the procedure and usual cost for example if I fly from Rome to Prague, how the border control checks me, how and what kind of taxes related to that particular flight do I pay. Please, don't miss anything.
I don't fly in the EU so I will refrain from commenting here.
Here in the US you are required to flight plan with enough fuel for your flight plus 30 minutes of reserve. I don't like when companies put range because this is very much based on the winds and your course. If you get a 40 knot tail wind you will very quickly increase your range, while a 40 knot headwind will bring the number back equally as much. I would calculate range based on usable fuel and fuel burn of the engine. but if they are saying 1900KM I would plan for the 1750KM range to be safe.
Aircraft service is (as far as I know) done on hours not miles flown (although they are related in a way. Here in the US you need a yearly inspection which includes lots of things like testing gear and other components and ever XXXX hours when your engine hits TBO (to be overhauled) you need to overhaul it. This overhall can be costly but is very dependent on the engine. It can range anywhere from 15K to (insert large number here). You are also responsible to have anything fixed should it break obviously.
Cost to park
There are 2 things here your storage cost and the cost when you actually go somewhere. I fly out of KPNE and have spoken to a few people about the cost of a tie down/hangar. It seems I can keep an airplane in a tie down for less than $100 a month but it would be outside all the time. Hangars get pricy and can be rented or bought. There are lots of small airfields where I am and I'm sure its possible to store a plane for cheaper than at KPNE.
As for going somewhere that depends on ramp fees. Here in the US these fees are sometimes waived if you buy gas or very nominal in the first place. Some airports also have a small landing fee (KPNE is $5). I don't know about EU (although I'm sure they have it) but here in the US you can get the AFD (airport facilities directory) which has lots of info on these kinds of things. Most airports/FOB's now have websites that list their prices as well.
Anything else you think is important to know about possessing and airplane of that type.
It seems you are looking for a fixed number to a question that does not have an answer like that. You must first identify your mission then you can find a plane to fit the mission profile. You can then look at the prices of other people who have owned that plane and you may find what you seek but you will also find that there is a HUGE deviation in the prices as no two planes are alike.
  • $\begingroup$ Almost an answer i was looking for. I know that it's not possible to present fixed prices. Not even possible for a car. However, if somebody could clarify more about: "bad weather", how strong winds, rain, storms? (anything to compare to?) And of course, flying internationally, how much does it cost to land somewhere "from-to"? And how much it can cost to park an airplane in bigger airport? Does this small airplanes fly over ocean or it's a no no due to something? $\endgroup$ – mariotanenbaum Mar 30 '15 at 14:15
    $\begingroup$ I will edit my answer to reflect some of these points. $\endgroup$ – Dave Mar 30 '15 at 14:29
  • $\begingroup$ great, thank you very much, i just hope somebody from Europe will add some info for EU about airport lending practice etc... $\endgroup$ – mariotanenbaum Mar 30 '15 at 14:46
  • $\begingroup$ Weather capability is much more likely to be limited by your ability rather than the plane. To fly in anything but clear weather (VFR), you will have to get an instrument rating, and stay current. This has considerable cost, both in money and time. $\endgroup$ – jamesqf Mar 30 '15 at 18:54
  • $\begingroup$ Jamesqf is 100% correct on this one, I was more addressing some of the physical limits of the aircraft. $\endgroup$ – Dave Mar 30 '15 at 19:34
