17
A "Sterile Cockpit" means avoiding all conversations and actions not related to flight during important flight times. (eg. No extraneous conversations, no non-important electronics, no eating, etc)
Commercial pilots are told to observe Sterile Cockpit below 10,000 feet.
But what about Private Pilots who may rarely ever go above 10,000? When do you begin observing sterile cockpit? When do you consider it safe to talk with passengers, take a snack, or fiddle with the new GPS?
15
The "sterile cockpit rule" is an informal name for 14 CFR 121.542 and 14 CFR 135.100. It says that no non-essential duties may be done during a critical phase of flight which is defined as "all ground operations involving taxi, takeoff and landing, and all other flight operations conducted below 10,000 feet, except cruise flight". In your example, once they level off at cruise, even if it is below 10,000 feet, it no longer applies.
While this doesn't apply to Part 91 operations like you describe, it is a very good idea to follow the rule anyway to prevent distractions and increase the level of safety.
As far as the GPS, I would recommend fiddling with it on the ground before you takeoff and be familiar with its operation before you need to use it. Being heads down for an extended period of time is never a good idea (unless you have a safety pilot along to keep an eye on things and look for traffic)!
The full text of the regulation is:
§121.542 Flight crewmember duties.
(a) No certificate holder shall require, nor may any flight crewmember perform, any duties during a critical phase of flight except those duties required for the safe operation of the aircraft. Duties such as company required calls made for such nonsafety related purposes as ordering galley supplies and confirming passenger connections, announcements made to passengers promoting the air carrier or pointing out sights of interest, and filling out company payroll and related records are not required for the safe operation of the aircraft.
(b) No flight crewmember may engage in, nor may any pilot in command permit, any activity during a critical phase of flight which could distract any flight crewmember from the performance of his or her duties or which could interfere in any way with the proper conduct of those duties. Activities such as eating meals, engaging in nonessential conversations within the cockpit and nonessential communications between the cabin and cockpit crews, and reading publications not related to the proper conduct of the flight are not required for the safe operation of the aircraft.
(c) For the purposes of this section, critical phases of flight includes all ground operations involving taxi, takeoff and landing, and all other flight operations conducted below 10,000 feet, except cruise flight.
Note: Taxi is defined as “movement of an airplane under its own power on the surface of an airport.”
NASA has a great article called The Sterile Cockpit which goes into a lot more information, and includes some interesting statistics from the ASRS database about accidents/incidents that were in some way caused by not following this regulation:
48% were altitude deviations
14% were course deviations
14% were runway transgressions
14% were general distractions with no specific adverse consequences
8% involved takeoffs or landings without clearance
2% involved near mid-air collisions due to inattention and distractions.
Abiding by the sterile cockpit rule can help you to avoid situations like that! The article also gives some examples from the database and talks about a couple of crashes that were attributed to lack of compliance.
  • $\begingroup$ Good answer with sources cited. But personally, I consider that too loose. I'm still in cruise flight until shortly before I enter the pattern for landing! I personally tend to move to Sterile Cockpit around 5 miles outside a class-D space, when I'm first calling a class-D tower and receiving instructions. $\endgroup$
    – abelenky
    Jan 27, 2014 at 16:26
  • $\begingroup$ @abelenky Yeah, the NASA article that I just added mentions that, and there is one mention of choosing a DME distance to comply. $\endgroup$
    – Lnafziger
    Jan 27, 2014 at 16:33
  • $\begingroup$ @abelenky By the way, I would say to start observing a sterile cockpit when you start your descent, which is normally a little further out than pattern entry. If you were cruising at pattern altitude (seems a little low to me!), then it would have to be earlier (maybe when you get the ATIS or start talking to approach). $\endgroup$
    – Lnafziger
    Jan 28, 2014 at 6:19
