Is it plausible for a pilot inside the cockpit to be incapacitated and that at the same time the pilot locked outside simply doesn't remember the code or the procedure for entering the cockpit?
2$\begingroup$ I would speculate that the answer here is the same as the answer to "Do you forget your banking PIN or the procedure for making a withdrawal?" -- People can forget ANYTHING (human memory is very unreliable), but we do tend to remember things that are important to us or that we do frequently - and presumably gaining entry to the cockpit is both important to a pilot and something they do frequently :) $\endgroup$ – voretaq7 Mar 26 '15 at 18:15
1$\begingroup$ That may not be a good assumption -- This was discussed a little bit in chat and basically there's no way for the person inside the cockpit to know if the one outside really forgot the entry procedures or if they're saying they forgot because someone has them at knifepoint trying to get one of the pilots to open the door. In that situation the safest course of action is to keep the door closed anyway… $\endgroup$ – voretaq7 Mar 26 '15 at 18:35
1$\begingroup$ Also related: The answers here & on the duplicates $\endgroup$ – voretaq7 Mar 26 '15 at 18:38
1$\begingroup$ @voretaq7, the pilot outside the cockpit needs to knock "7500" so the pilot inside knows he's been hijacked. (3/4 in jest...) $\endgroup$ – FreeMan Mar 27 '15 at 14:52
1$\begingroup$ @FreeMan This also works. $\endgroup$ – voretaq7 Mar 27 '15 at 16:05
The code would also be shared among the purser and/ or the other flight attendants, so the answer is no. I believe however that they tend to keep the same code for a few days within the same crew to make remembering it easier.
3$\begingroup$ Perhaps you might explain who sets the code, and whether it is tested (by someone else) after being shared by that person with (the) others? $\endgroup$ – Keep these mind Mar 26 '15 at 16:28
$\begingroup$ From the press conference Lufthansa gave on March 26, or sounded like they all have the code ready to quote when they are being woke up at midnight. It sounded though as if the code was never or rarely changed, but I guess that was more a poor choice of words then the truth. The code must be changed every now and then. $\endgroup$ – Maverick283 Mar 27 '15 at 5:19
$\begingroup$ @Maverick283 "Every now and then" may but refer to quite a long period. After all even a leaked code can be ovrerridden from within the cockpit. $\endgroup$ – Hagen von Eitzen Mar 27 '15 at 18:20
$\begingroup$ @HagenvonEitzen I know hence a comment and know answer and I simply have no idea at all in which interval this code is changed. $\endgroup$ – Maverick283 Mar 27 '15 at 18:21
$\begingroup$ Does it mean you need to re-learn 7-digit numbers again and again, knowing that probably you won't ever need them even once in your life? $\endgroup$ – Gray Sheep Apr 20 '15 at 7:22
