13
If there were nobody at the controls what kind of vertical profile could be expected from, for example, a modern airliner?
After reaching the cruise altitude I assume the pilot just sets a nav route and altitude on the onboard computer or at least set the trim to avoid having to constantly adjusting the altitude manually.
4 Answers 4
15
Emergency descent (like during a decompression event where you need to get from cruise to 10k ft ASAP to make sure the people in the back survive) shouldn't make a nice curve. It only wastes time you don't really have.
Normal operation means the pilot activates the autopilot during cruise which will fly the programmed course set by the pilot. It will stay follow that course (or put itself in a holding pattern on the final fix) until it runs out of fuel or the pilot intervenes when it is cleared for descent. This happened with Helios Airways Air flight 522; both pilots were incapacitated shortly after ascent and the plane put itself in a hold and crashed when it ran out of fuel after more than an hour.
A plane where there is nothing controlling the altitude (when control is lost due to loss of hydraulics for example) will follow a phugoid cycle. That is a series of dives and climbs as the elevators gain and lose bite on the air with speed.
  • $\begingroup$ Ok i understand that this may fit the profile of an emergency descent. But am i right about thinking that doesnt fit how an unmanned airplane is supposed to lose altitude if no autopilot is set? $\endgroup$
    – Bolza
    Mar 26, 2015 at 12:27
  • $\begingroup$ @Bolza I added a section for truly unpiloted crafts $\endgroup$ Mar 26, 2015 at 12:37
  • $\begingroup$ A phygoid is unlikely in a naturally stable aircraft with ordinary aerodynamics. It is much more likely to fall into a spiral dive. $\endgroup$ Mar 27, 2015 at 9:38
  • $\begingroup$ @PeterKämpf if the plane is stable in roll then it won't go into a spiral dive, $\endgroup$ Mar 27, 2015 at 9:49
  • $\begingroup$ @ratchetfreak: Yes, indeed. If. $\endgroup$ Mar 27, 2015 at 12:20
Any descent profile can be expected of an unpiloted aircraft, but generally nothing severe would be expected uncommanded and without stall occuring. Aircraft control surfaces (rudder, elevator, aileron) can be "trimmed" to maintain coordinated level flight. Elevator trim, in particular, is constantly adjusted (by the pilot or autopilot) so that if nothing was flying the plane it would maintain its present airspeed. A consequence of this is that a properly trimmed airplane will climb or descent to maintain the airspeed it is trimmed for.
Give the above we can say a properly trimmed aircraft with no pilot input could be expected to roughly maintain altitude and once out of fuel it will descend at whatever rate is required to maintain its trimmed airspeed.
The above assumes no autopilot or an autopilot in speed hold mode. An autopilot in altitude hold mode will attempt to maintain altitude as long as possible, and depending on the programming that might mean until stall occurs. When the stick shaker activates preceding the stall, that should disconnect the autopilot and this may be followed by stick pusher activation. In the end, if stall is avoided, the airplane will descend at the airspeed that autopilot last trimmed it for, which is likely a slow-ish airspeed (close to but above stall speed at present altitude).
Large commercial aircraft are not expected to descend if their pilots just walk way. At least, not quickly. Large planes generally cruise on autopilot, which will keep altitude until told otherwise. In fact, airliners generally have flight management computers that will fly the entire route before holding near the destination. When the plane runs out of fuel, it will slow down and then, finally, it will descend until it crashes. This was seen in Helios 522. I don't know what that descent profile would look like.
The Helios 522 accident report shows the following
Aircraft enters from bottom right. AP lines up aircraft with Athens International airport runway. after overflying airport, AP turns SE and puts aircraft on holding pattern (loop at bottom). Fuel exhaustion causes one engine to flame out and AP to disengage. Aircraft starts to bank (assymetric thrust) and turns. Second engine flames out. Final descent is on a roughly spiral track.
All certified airplanes are designed to have a (very slight) spiral instability. The opposite case, dutch roll instability is not acceptable. This will make a plane that is trimmed out straight and level and then left alone without pilot, autopilot wingleveler or other automation to slowly enter a spiral dive with gradually increasing bank angle and sink rate.
Spiral instability is achieved by having the lateral tail area large enough so when a wing drops slightly by external disturbance and the plane starts to slip in the wing low direction, the tail will turn the plane in the same direction as the wing drop. This is a gentle and harmonic movement, it feels natural to the pilot. If uncorrected it leads to a spiral dive at increased bank angle and speed.
Dutch roll is the result of to small tail area, so when the plane slips for instance to the left, the nose will go right and up. The speed will go down, and if uncorrected will lead to a stall.
It is not the case that a plane left unattended (no pilot or autopilot on duty) will largely stay on course and altitude until the fuel runs out. If a plane was stable by itself, flight in low visibilty would not be a problem.
One famous example is the John F. Kennedy Jr. accident.
http://en.wikipedia.org/wiki/John_F._Kennedy_Jr._plane_crash
  • $\begingroup$ This is a very interesting answer! I think it'd be useful to expand on why airplanes must have this instability, and what Dutch roll stability is. $\endgroup$ Mar 29, 2015 at 1:26
  • $\begingroup$ What this answer calls "spiral instability" is a natural consequence of having good yaw stability. That is, a banked attitude causes the aircraft to turn into the bank, rather than slipping sideways. Wing dihedral also provides some roll stability, tending to keep the aircraft upright, but if this exceeds the yaw stability a "dutch roll" oscillation can result. In normal circumstances, heading is maintained either by the pilot or by an autopilot, the simplest being a simple wing-leveller. $\endgroup$
    – Chromatix
    Apr 7, 2018 at 5:27
