106
In the wake of GermanWings' terrible incident of flight 9525, I have noticed that the crash location is quite far from the shortest route connecting the two airports.
I then went on FlightRadar24's website and checked that this is the normal route for this flight (and that there is an alternate one that reaches equally far on the other side):
Other companies that fly the same route (Vueling 1894, Airberlin 8947) follow the same flight paths.
Why is this? What limitations are in place that prevent these aircraft from flying over Lyon (and "nearby" region)?
130
Large parts of France's airspace are designated military training areas. If there is military flight training going on, the choice of routing over France is very limited. The only option is to fly around these areas, which results in the routes you found.
Higher altitude route map of France courtesy of EUROCONTROL[PDF, 8MB]
Since the PDF seems to be giving problems on some computers, I've combined several screenshots and drew the approximate route of your westerly flight (in yellow), the planned flight of GWI 9525 (blue) and Temporary Segregated Airspaces (TSA's) in red onto the map. The crash location of GWI 9525 is marked by a red/yellow star. enter image description here
Note that not all the TSA's in the map are actively used at all times and that in some cases crossing is allowed but altitude restrictions apply.
In addition to active TSA's there are other considerations that come into play such as weather and airway capacity & demand. If you have to wait 15 minutes longer for a slot on the shortest route, you might as well fly a slightly longer route if that allows you to depart earlier.
    $\begingroup$ It is possible that route segments through the LF-R or LF-D airspaces are only available during certain times, mostly at night. You would have to go through France's AIP to figure it out in detail. $\endgroup$ Mar 24, 2015 at 12:23
  • 27
    $\begingroup$ I was on a flight once that went straight between BCN and DUS (or FRA?). I happened to be in the cockpit. The pilots were surprised about the route they got as normally on weekdays they have to fly the dogleg. $\endgroup$
    – DeltaLima
    Mar 24, 2015 at 12:24
  • 42
    $\begingroup$ This answer got cited by the Swiss news paper Tagesanzeiger: tagesanzeiger.ch/panorama/vermischtes/… $\endgroup$
    – drat
    Mar 25, 2015 at 7:55
    $\begingroup$ @drat: Thanks for the link. They have some pretty high resolution pics of the black box / cvr. $\endgroup$
    – Firee
    Mar 25, 2015 at 12:25
    $\begingroup$ It does not seem to be the full explanation. Based on the map, it seems there is a direct route from somewhere around Toulouse to Lyon and Geneva that does not cross any of the red areas and would seem more direct (start with the yellow route and then head NE to reach the end of the blue route). There must be other considerations. $\endgroup$
    – Relaxed
    Mar 26, 2015 at 9:16
15
While DeltaLima's answer is very good, it is also due to Air Traffic Control limitations-- you want to spread out where the traffic is across the whole airspace, so routes may dogleg left or right at one point to try to keep traffic flow good (also helps separate aircraft going in opposite directions, but altitude does that too).
Keep in mind that the arrival patterns into certain airports have defined entry points and are designed to line up the plane in a certain way for the airport, and flights may have to go slightly out of their way to join the arrival.
