How does conventional flight work?
Explain what factors are in play in order to get a plane airborne and stay there.
    $\begingroup$ Related meta.SE discussion $\endgroup$
    – Pondlife
    Mar 23, 2015 at 13:32
    $\begingroup$ These answers are not entirely complete... in the larger sense, what makes an airplane fly is: money! $\endgroup$
    – Ralph J
    Mar 23, 2015 at 18:01
  • $\begingroup$ So I don't agree that this is a duplicate, as the linked question asks for a simplified answer. That being said, I also don't agree with the way that the answers that are currently here have been done. An answer is supposed to be "one definitive answer" and not a series of answers because the order of display is not consistent. Combining the two existing answers together into one CW would be more appropriate. $\endgroup$
    – Lnafziger
    Mar 23, 2015 at 20:07
  • $\begingroup$ @Lnafziger is there any way to link to subsections within an answer? $\endgroup$
    – Erich
    Mar 23, 2015 at 22:32
  • $\begingroup$ @erich Not that I am aware of, unfortunately. $\endgroup$
    – Lnafziger
    Mar 28, 2015 at 18:04
Four Fundamental Forces
Weight
Weight is the force of gravity acting upon an object's mass. The mass of an airplane is the sum of all parts that make up the airplane, including fuel and lubricating oils, crew/passengers, and cargo. In a normal flight attitude, this force acts in the down direction, and it will always act towards the earth's center of gravity.
The airplane's center of gravity, or CG, is the location where the aircraft's mass/weight is evenly distributed in all directions. Optimally, the CG should be as close as possible to the airplane's center of lift.
Lift
In a normal flight attitude, lift is the force opposing weight, acting in the up direction. It is produced by the interaction of the wings and fuselage with the surrounding air as the aircraft travels through.
There are three scientific principles at work in the production of lift as it applies to aircraft.
  1. Bernoulli's Principle: As air travels faster, its pressure decreases. A typical airplane wing is designed like a foil, where the upper surface is comparatively rounder than the lower surface. Air flows faster and at lower pressure over the top of the wing than air flowing underneath it, actually arriving somewhat earlier at the trailing edge than the air traveling underneath the wing. This pressure difference accounts for most of the lift, but not all.
  2. The Coandă Effect: Airflow is attracted to nearby surfaces. Air "hugs" the wing as the wing passes through it. Additionally, since the airflow over the wing is faster than that below the wing, the net result after the wing has passed through is downward air movement. As the wing angle relative to the initial airflow (the angle of attack) increases, the trailing airflow is increasingly deflected downward. (However, too much angle of attack will result in disrupted airflow on the leeward side of the wing, causing the wing to stall, resulting in a loss of lift.)
  3. Newton's Third Law of Motion: A force in one direction caused by an object is countered by an equal force upon that object in the opposite direction. Air deflected downward off the trailing edge of the wing results in a simultaneous upward force on the wing itself.
Drag
Drag is the force of all friction acting upon the airplane, operating in the backward direction.
Drag comes in many varieties. Skin friction is the resistance caused by moving a solid object (the plane itself) through the air. Induced drag occurs at the wingtips, where the high pressure air below the wing flows into the low pressure region above the wing, creating inwardly rotating swirls of air (vortices) behind the airplane. Additional drag is encountered as an airplane's speed approaches the speed of sound and beyond.
Thrust
Thrust is the force causing the aircraft to move forward through the air. In most airplanes, thrust is produced by a propeller or jet engine. This is Newton's Third Law in effect as well: as air is pushed backward, the aircraft moves forward. This forward motion creates a flow of air over the wing, producing lift.
When an airplane's thrust produced equals its drag, the airplane remains in level flight (barring any pilot control inputs). When thrust exceeds the drag, the increased airflow over the wing creates additional lift. When thrust is less than drag, the decreased airflow results in less lift being generated.
  • $\begingroup$ Not to sure how much of the lift actually cones from bernoulli and how much from the other two but I think it should read "This pressure different accounts for *most* of the lift, but not all" to make it clearer. $\endgroup$ Mar 23, 2015 at 14:47
  • $\begingroup$ @Maverick283 it's a community wiki answer, please edit as you wish. $\endgroup$
    – CGCampbell
    Mar 23, 2015 at 16:29
    $\begingroup$ @maverick283 these could be opinionated sources, but walter lewin estimates only around 20% of all lift generated is due to bernoulli (at least on a 747). ga tends be slightly higher, up to around 1/3. this is why i left it "some". $\endgroup$
    – Erich
    Mar 25, 2015 at 4:49
